Pollen Infoscreen
IMPORTANT: Please request a new API key to use in the associated script (see first collapsible block below).
For more info on the deployment on HW please check our Target Setup Guide.
Overview scene:
Dynamic Elements:
- Clock control
- Air Quality – text value
- DayRisk control (4 week days)
- Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
Insights scene
The insights scene features a list of all available contaminant information available via WebAPI. The list hierarchy is taken over from the WebAPI data and is usually ranked by strongest to weakest contaminant (with the strongest contaminant on the top of the list).
- ContaminantName control
- 4 x ContaminantLevel
Controls
Associated script (WebAPI)
DayRisk
PollenBrief
MultihourValue
ContaminantLevel
ContaminantName
ContaminantsListElement
Contaminant
Country
Contaminants_List
GroupBox_List
Scenes
State Machine
Overview Scene
Insights Scene
This scene only contains a list of the contaminants we know of and their level. It is only meant to be viewed, there are no buttons for interaction. The elements of the list are ContaminantListItem templates. The list has a fixed number of 8 elements. The number of received contaminants can be higher or smaller. If Higher, we only show the first 8. If lower, we disable rendering for the unused elements via a “Render Child Nodes” behavior. When there are more elements than visible in the given space, a scroll-bar will appear (and scale move itself appropriately). To customize the “Scrollbar” with imported graphical elements, the Contaminants_List template is used.
TopBar Scene
BottomBar Scene
In the bottom bar we have buttons to switch between the 2 main scenes. When the button is clicked, the state machine transition occurs. To select between the gray and green versions, a RenderChildNodes behavior is used, and the related value is set by pressing, and databound, to allow the app to know which scene is currently active.
ContaminantList_Popup Scene
Location_popup Scene
This is the largest scene in the solution. There are 2 lists visible, a countries list and a cities list. In the scene there is a list of cities for each country. The Lists of cities are under a node with a “Render Child Nodes” behavior, so only one of the lists of cities is made visible. The index of the list to show is set from the “Country” template of the first list. Like the Contaminants List Popup, this scene has a node prevent events going to the elements under it, and a full screen button to exit when tapping outside.
Animations
