Pollen Infoscreen
For more info on the deployment on HW please check our Target Setup Guide.
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality – text value
  • DayRisk control (4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
  • City Button (triggers location list)
  • Insights Button (switches to contaminants list scene)
Insights scene
The insights scene features a list of all available contaminant information available via WebAPI. The list hierarchy is taken over from the WebAPI data and is usually ranked by strongest to weakest contaminant (with the strongest contaminant on the top of the list).
ContaminantListElement control – List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk
PollenBrief
MultihourValue
ContaminantLevel
ContaminantName
ContaminantsListElement
Contaminant
The Radio button has a “Value” behavior, which will become true when selected, and false when deselected. Under this value we have 2 “Action On Value” behaviors, one to trigger actions when becoming selected, and one to trigger actions when becoming unselected.
Country
City
The city button template has to send the city name, the country code, and the longitude and latitude of the city. These could naturally be represented as floating point numbers, but they will be needed as strings when creating a web request anyway, so we can set them to string type. The country code is sent from here and not the country list, to keep them consistent, in case the country is changed and no new city is selected.
The app has 2 main scenes, the “Overview” and the “Insights” scene, and can switch between them using the buttons on the bottom bar. The “TopBar” and “BottomBar” scenes are always loaded and visible. For selecting items from lists, there are also some smaller scenes always loaded, and their visibility is controlled by triggering animations: “Location_Popup”, “ContaminantsList_Popup” and “Language_Popup”.
Contaminants_List
GroupBox_List
Scenes
State Machine
Overview Scene
This scene is the most complex of the solution, but it can be managed easily by using several of the templates previously described.
TopLeft: Here we just have a number from 0 to 10, showing the allergy risk for today, and some static text around it. A default “Text Value” control is used, and configured with font style, color, format and data binding.
TopRight: Here we have a list of allergy risk values for today and the next 3 days. Beside the value and day of the week, each also has an icon and fixed text for none, low, moderate, or high risk. For this we use the DayRisk template, and a StackLayout to allign them automatically.
Bottom Left: This displays the allergy risk values during the current day, at 4 hour intervals. The web api provides hourly values, and we display 6 of them, using images associated for value, via the MultihourValue template. The elements are also allligned automatically using a StackLayout.
Bottom Right: Here the user can select a set of 4 contaminants and see the risk level associated with each of them. There are only 4 levels: none, low, mid, high, and no numeric value. We use the PollenBrief template and place them manually. Each element has an associated button, which opens a list from which a user can select a contaminant for the respective slot.
Insights Scene
This scene only contains a list of the contaminants we know of and their level. It is only meant to be viewed, there are no buttons for interaction. The elements of the list are ContaminantListItem templates. The list has a fixed number of 8 elements. The number of received contaminants can be higher or smaller. If Higher, we only show the first 8. If lower, we disable rendering for the unused elements via a “Render Child Nodes” behavior. When there are more elements than visible in the given space, a scroll-bar will appear (and scale move itself appropriately). To customize the “Scrollbar” with imported graphical elements, the Contaminants_List template is used.
TopBar Scene
BottomBar Scene
In the bottom bar we have buttons to switch between the 2 main scenes. When the button is clicked, the state machine transition occurs. To select between the gray and green versions, a RenderChildNodes behavior is used, and the related value is set by pressing, and databound, to allow the app to know which scene is currently active.
ContaminantList_Popup Scene
Location_popup Scene
This is the largest scene in the solution. There are 2 lists visible, a countries list and a cities list. In the scene there is a list of cities for each country. The Lists of cities are under a node with a “Render Child Nodes” behavior, so only one of the lists of cities is made visible. The index of the list to show is set from the “Country” template of the first list.  Like the Contaminants List Popup, this scene has a node prevent events going to the elements under it, and a full screen button to exit when tapping outside.
Animations
Associated script
