Plugin Options
Plugins Available
Available plugins are displayed under  [ Plugins ] in the Preferences dialog.
All available plugins are displayedenabled inby "Preferences"default. >To "Plugins"disable ona plugin, click the button to the right sideof its properties. When the button displays "Enable," the plugin is disabled.
Plugin Name Description Note AstcBitmapConverter This is an ASTC bitmap converter. Converts RGBA unsigned byte data to ASTC RGBA. Details Used Behavior plugin A plugin that generates info on Behavior types referencesd in solution for use by CMake build. ー Cgi-Studio Image Update This is a plugin for the Image Update function. Details CommandLinePlugin This is a plugin for executing commands when generating assets. Details List Property Editor
This is a plugin for the List Editor. The List Editor can be used with controls such as BarGraph and LineGraph.
Details SpecificationPlugin
This is a plugin for Define application specification. Define application specification is required to link data binding sources with Scene Composer.
Details DataBindingEditorPlugin
This is a plugin for the Data Binding bind icon and Live Preview panel.
Details Dirty Area Dependency Plugin This is a plugin for Dirty Area Management (DAM). Details ExecutableGenerationPlugin
This is a plugin for executing scripts when generating assets.
Details ExternalResourceContainerPlugin This is a plugin for the Referencing external resource function.
Details iMX6 Shader Compiler This is a shader compiler for iMX6. Details RCarD3 Shader Compiler This is a shader compiler for RCarD3. ー RZA1HBitmapConverter This is a bitmap converter for RZA1H. ー Cgi-Studio Transrator This is a plugin for Localization. Details Traveo2BitmapConverter This is a custom bitmap converter for Traveo2. ー
Plugin-Specific Settings
ASTC Configuration
Setting item name Description Compression Speed
The Compression Speed can be set to one of five levels.
Behavior Config Generation
Setting item name Description Behavior Configuration Enabled
If enabled, a Behavior configuration will be generated.
Destination path
Set the path to the CMake file in the CMake flag "CONTROLS_USED_BEHAVIORS_CONFIG_PATH".
Commnad Line
Setting item name Description Command Line
Sets the command to be executed when generating assets.
Setting item name Description Include in asset
If enabled, information about Dirty Area Management will be output to the asset.
Setting item name Description Generated output format
Select the output format from three options (Text, Binary, or Binary program).
Custom command line string
Enter the tool or identifier to execute in command line format. This setting can only be set when the output format is Binary or Binary program.
Translator
Setting item name Description Export always If enabled, all translated text will be included in asset. Export Only Used Translatable Texts If enabled, only translated text used in behaviors, etc. will be included in assets. Enable Language Pack Source Monitoring If enabled, Language Pack Source files will be monitored. Language Pack Source Set the Language Pack Source to be monitored. Solution Path The root path of the panel.solution
will be displayed.
Changes
to
Plugin Plugin-Specific Optionssettings will take effect after restarting Scene Composer.
Plugins can register option editor dialogs via SceneComposer SDK.
