Select Features
CMake feature switches have been renamed for V3.x releases, see Change Log
Select Candera Features
Build settings for the Candera Engine are specified by the following CMake variables:
| Name | Description | Possible values |
| CANDERA_2D_ENABLED | Enables Candera engine's 2D elements. If both 2D and 3D are enabled, the solution will contain both CanderaEngine2D and CanderaEngine3D subprojects. |
ON/OFF |
| CANDERA_LAYOUT_ENABLED | Enables Candera 2D dynamic layout. If disabled, the whole code for dynamic layout is removed. |
ON/OFF |
| CANDERA_LAYOUT_CLIPPING_ENABLED | Enables clipping of Candera 2D dynamic layout. If enabled, the render area of a render node is clipped to the layout area. |
ON/OFF |
| CANDERA_3D_ENABLED | Enables Cander engine's 3D elements. | ON/OFF |
| CANDERA_VRAM_ALLOCATOR_CHECK_ENABLED | ON/OFF | |
| CANDERA_VRAM_ALLOCATOR_STATISTICS_ENABLED | ON/OFF | |
| CANDERA_RENDER_STATE_CACHING_ENABLED | Whether or not Candera shall cache render states.
ON/OFF |
| CANDERA_DETAIL_STATISTICS_ENABLED | Whether or not Candera shall keep statistics about render state cache hits and misses.
ON/OFF |
| CANDERA_GLOBALIZATION_ENABLED |
Whether or not Candera Globalization library shall be built.
ON/OFF |
| CANDERA_ASSET_DECOMPRESSION_ENABLED | This option is required to decompress asset data if it was compressed with CGI Studio Asset Library Shaper previously.
ON/OFF |
| CANDERA_TEXT_SHAPER |
Allows the selection of a text shaper.
NoShaping ComplexScriptLib Harfbuzz - Default |
| CANDERA_BIDIRECTIONAL_TEXT_ENABLED | Allows enabling of bidirectional text parsing. This is needed when combining text written left to right with text written right to left. If the text shaper supports bidirectional text this option is required when using multi-font text styles. |
ON/OFF |
| CANDERA_TEXTENGINE_NATIVE_LINEHEIGHT_ENABLED | Whether or not the native line height metrics of the font engine is used. If disabled then 120% of EM size is applied as line height which is compatible with Adobe. |
ON/OFF |
| CANDERA_ASSETLOADER_MEMORYPOOL_ENABLED | Enables the use of the Memory Pool feature in Candera AssetLoader.
ON/OFF |
| CANDERA_TEXTENGINE_MEMORYPOOL_ENABLED | Enables the use of the Memory Pool feature in Candera TextEngine.
ON/OFF |
| CANDERA_ASSET_LIBRARYHEADER_CACHE_ENABLED | Optional feature which will cache all Asset-Library-Header that have been loaded and cached upon Asset initialization.
ON/OFF |
Select FeatStd Features
For information about FeastStd features, please refer to FeatStd > FeatStd Features.
