View Tree
View Tree is the editor for arranging View in the solution as a tree and composing screen transition logic based on that structure. When you define transition relationships between Views on the tree, that information is exported as the Global State Machine at asset generation and becomes available as destination candidates for the JumpToView action behavior.
When you set a parent–child relationship between Views, the child View is activated in sync when the parent View becomes active, allowing you to manage groups of screen elements that should always be shown together. In addition, by associating an Action Chain created in the Action Chain Editor with each View, you can define that View’s event logic and conditional transitions.
View Tree panel UI
By default, theThe View Tree panel is hidden.hidden by default. To displayshow it,the choosepanel, do either of the following:
    Select View > View > View Editor > View Tree from the menutoolbar bar.menu.
    In Solution Explorer, double-click an existing View Tree.
    1 Zoom icon Zooms the previews of Views in the View Tree.
    2 Expand/Collapse icon
    Appears when a View has child Views. Click to toggle the visibility of the child Views.
    Basic operations
    Create a new View Tree
    Follow these steps to create a new View Tree:
      In Solution Explorer, open the context menu at the desired location.
      Choose Add > New Item.
        The Add New Item dialog opens.
        In the dialog’s left pane, select View Tree, then click OK.
          The value you enter in Name becomes the new View Tree’s name.
          A new View Tree is created in Solution Explorer.
          Double-click the newly created View Tree to launch the Condition Editor.
          For the View Tree you created, you can use the standard operations in Solution Explorer to copy, duplicate, delete, and rename it.
          Place Views
          Drag and drop Views that you have defined beforehand in the View Definition Editor onto the View Tree panel.
          • Dropping onto a blank area of the View Tree panel places the Views side by side (as peers).
          • Dropping onto an existing View places the dropped View as that View’s child.
          When a parent–child relationship is set between Views, the child View’s event logic is activated in sync when the parent View becomes active.
          Configuring in Action Chain Editor
          For each View placed on the View Tree, you can configure its event logic in the Action Chain Editor. You can launch the Action Chain Editor in either of the following ways:
          • Double-click the View you want to configure.
          • Select the View and choose Open Action Chain Editor from the context menu.
          Exported as a Global State Machine
          • The information you build on the View Tree (relationships between Views and their transition logic) is exported as a Global State Machine when assets are generated.
          • The exported state machine is then executed on the engine side via JumpToView-related events/actions to control the actual screen transitions.
