Action Chain Editor
Action Chain Editor is a visual editor for composing a View’s event logic on a per-trigger basis. Starting from user input or system events, you can define transitions between Views, play animations, and build complex event-driven behaviors—visually and intuitively—as Action Chain diagrams composed of Trigger, Action, and Condition nodes.
Operations on the Action Chain Editor panel are available only after you have created a View in the View Tree.
Any Condition Block nodes used inIn the Action Chain EditorEditor, musta beCondition node references the Condition Output created beforehand in the Condition Editor. You must define a Condition Block—and within it the Condition Output that represents the evaluation result—beforehand.
Action Chain Editor panel UI
Panel layout
The Action Chain Editor consists primarily of the following two panes.
By default, the Action Chain Editor panel is hidden. To display it, choose View > View Editor > Action Chain Editor from the menu bar.
UI items Description
Left pane (orange frame in the figure above)
Manages multiple Action Chain diagrams in a list. You can organize diagrams by feature or by input device, and perform operations such as creating, opening, renaming, and deleting.
Right pane (red frame in the figure above)
The workspace for editing the selected Action Chain diagram. Place and connect Trigger, Action, and Condition nodes to define the processing flow.
Left pane
On the left pane, you can use the context menu to perform the following:
Menu Description
New Diagram Create a new Action Chain diagram.
Open Open the diagram selected in the left pane.
Rename Change the name of the diagram selected in the left pane.
Delete Delete the diagram selected in the left pane.
Right pane
On the right pane of the Action Chain diagram, you can place and connect the following nodes from the context menu. The properties of each node placed on the diagram can be edited in the Properties panel.
Menu Description
Add Trigger
Add Trigger Select a trigger node that serves as the entry point of the Action Chain. Specify
Use this menu to select the Condition behavior or Behavior Building Block (including Condition behaviors) that you want to use as the trigger. You can also create it by dragging and dropping a Condition behavior from the toolbox.
Add Action
Places a node that represents the action to execute. Specify
Select the Action behavior to use (for example, switching a ViewViews or playing an animation). or a Behavior Building Block (including Action behaviors) that you want to use. You can also create it by dragging and dropping an Action behavior from the toolbox.
Add Condition
Places/referencesSelect athe Condition Block nodeConditionOutput created in the Condition Editor, or a Behavior Building Block (including Condition behaviors). Branches the subsequent flow (true/false) based on the evaluation result.
  • If no Condition BlocksConditionOutputs are defined in the Condition Editor, this menu is not shown.
  • Condition BlocksConditionOutputs that are not configured correctly are not listed in this menu
Add After
Defines processing that must run afterwards regardless of whether the condition evaluated to true or false. Use this to express post-processing or common flows.
Add Else Used together with Add Condition menu to construct an if/else if/else logic structure.
Copy Shown when a node is selected on the right pane. Copies the selected node.
Paste
Shown after performing Copy or Cut. Places a duplicate of the copied/cut node onto the diagram.
Cut Shown when a node is selected on the right pane. Cuts the selected node.
Delete Shown when a node is selected on the right pane. Deletes the selected node.
Basic operations
Create a new diagram
To create a new Action Chain diagram, first select the target View in the View Tree panel.
  1. In View Tree, select the View you want to define an Action Chain for.
  2. Open the Action Chain Editor using either of the following:
    • Double-click the target View
    • Right-click the target View and choose Open Action Chain Editor.
  3. In the left pane of the Action Chain Editor, open the context menu and select New Diagram.
    • A new Action Chain appears in the left pane.
    • Rename the diagram as needed.
Place a Trigger node
In an Action Chain diagram, start by placing a Trigger node that specifies “when to run.” The trigger hands off execution to the subsequent Condition group.
Place it on the right pane in either of the following ways:
  • Right-click the right pane and choose Add Trigger, then select the trigger behavior to use from the list.
  • Drag the desired trigger behavior from the toolbox onto the right pane.
Place Condition BlockConditionOutput and Action nodes
A ConditionOutput (defined within a Condition BlockBlock) and an Action together represent one “if line.”
A Condition BlockConditionOutput node must be created beforehand in the Condition Editor.
  • On the right pane, open the context menu and choose Add Condition to place a Condition BlockConditionOutput node.
    • This node references a Condition BlockConditionOutput created in the Condition Editor.
  • For processing that should run when the Condition BlockConditionOutput evaluates to true, choose Add Action to place an Action node.
    • Placing an Action node immediately to the right of a Condition BlockConditionOutput has the following meaning:
      Condition_1 + Action_1 → if (Condition_1) { Action_1(); }
  • Placing another Condition BlockConditionOutput vertically below an existing Condition BlockConditionOutput creates an if / else if / else block that is evaluated top to bottom (see the next section, “if/else if/else logic”).
In an Action Chain diagram, you express if / else if / else by how you arrange Condition BlocksConditionOutputs and Actions.
  • Single row (side by side)
    • Placing a Condition BlockConditionOutput on the left and an Action on the right represents if (Condition_X) { Action_X(); } (see Case 12 below).
  • Stacked conditions in the same column
    • From top to bottom, the rows are evaluated as if → else if → else (see Case 3).
    • Rows that include a Condition BlockConditionOutput correspond to if/else if, and a row that has only an Action corresponds to else (see Case 6).
  • Nested if
    • Connecting from an Action node to another Condition BlockConditionOutput node creates a nested if, which evaluates an additional condition after that Action (see Cases 2 and Case 7).
Using After nodes
An After node is used to gather the “exits” of multiple branches into one.
  • If you connect lines from multiple Condition rows to the same After node, all of those branches merge at that After.
    • Any Action placed to the right of an After node will always run next, regardless of which path was taken.
  • If you insert an After node and then start a new Condition group, you can build a structure that “executes multiple independent if blocks in sequence under the same trigger” (see Cases 4 and 5 below).
  • Even if an After node is present, processing ends there unless you connect an outgoing line. Therefore, placing an After node is not mandatory; however, adding one helps to:
    • Clearly mark the end of a branching block, and
    • Make it easier to add common post-processing later.
Action Chain Configuration Examples
This section shows how node arrangements on the Action Chain diagram (right pane) correspond to example if statements.
Case 1: Basic single-condition if
The simplest Action Chain: one condition and one action.
  • A trigger (Check Click) detects the event; if the condition evaluates to true, a single action (Set Color) runs.
if (Check Click)
    Set Color();
Case 2: Nested if (side-by-side layout)
This configuration shows how to represent a nested if that evaluates another condition within the branch of an existing condition.
Arrange the nodes in a single row as: Trigger -> Condition_1Condition -> Action (Set Color) -> Condition_2 -> Action (Set Color_1)Color).
  • First, if Condition_1Condition is true, run Set Color.
  • Then evaluate Condition_2; if it is true, also run Set Color_1Color.
With this horizontal (side-by-side) layout, you can express “an if inside an if” as a nested conditional that is evaluated after the preceding Action.
if (Check Click)
    if (Condition_1)Condition)
        Set Color();
        if (Condition_2)
            Set Color_1(Color();
Case 3: Exclusive branching (if / else if)
This configuration shows how to evaluate multiple conditions for the same event exclusively (if / else if) so that only one action runs.
Place two rows—Condition_1Condition and Condition_2—stacked vertically one column to the right of the Trigger, and place their corresponding Actions (Set Color / Set Color_1Color) to the right of each row. This represents:
  • Upper row: if (Condition_1)Condition) { SetColor(); }
  • Lower row: else if (Condition_2) { SetColor_1(SetColor(); }
To make the branch’s common exit explicit, place a single After node at the end of the block formed by Condition_1Condition and Condition_2. The After node denotes “the exit for this if/else if group,” and all subsequent processing should connect to the right of the After node. With this layout, it is visually clear that regardless of which condition is met, the flow ultimately merges into the same continuation.
if (Check Click)
        Set Color();
Case 4: Two independent if blocks under the same Trigger
This configuration evaluates two Conditions independently and in sequence within a single Trigger.
  • The After placed beneath the Condition_1Condition + Set Color row is a mandatory exit: the flow passes through it whether Condition_1Condition is true or false, and then proceeds to Condition_2.
    • As a result, Condition_2 is always evaluated, regardless of the outcome of Condition_1Condition.
  • The After_3After_1 placed beneath the Condition_2 + Set Color_1Color row marks the end of the entire chain.
By contrast with Case 3, where stacking Condition BlocksConditionOutputs in the same column and using a single After yields exclusive branching (i.e., the next Condition is checked only if the previous one was false), Case 4 inserts an intermediate After between the rows so that both if blocks are evaluated in order.
if (Check Click)
        Set Color();
    if (Condition_2)
Case 5: Independent if + subsequent if/else if group
This configuration combines a single standalone if followed by an if / else if branching group under the same Trigger.
  • Row 1 (Condition_1Condition + Set Color) corresponds to:
    • The After directly beneath Row 1 is a mandatory exit. The flow passes through it whether Condition_1Condition is true or false, and then proceeds to the group formed by Condition_2 and Condition_3.
  • Rows 2 and 3 (Condition_2 + Set Color_1Color, Condition_3 + Set TextImage) represent:
    if (Condition_2) { SetColor_1(SetColor(); } else if (Condition_3) { SetText(SetImage(); }
    • When Condition_2 is true, only SetColor_1(SetColor() runs; only when it is false is Condition_3 evaluated.
  • The After_2After_1 beneath these two rows is the common exit for the if / else if group.
Compared with Case 4, where both Condition_1 and Condition_2 were independent if blocks, Case 5 has an independent if for Condition_1, followed by an if / else if group formed by Condition_2 and Condition_3.
if (Check Click)
        Set Color();
    if (Condition_2)
        Set Text(Image();
Case 6: Three-way branching (if / else if / else)
This configuration shows a classic exclusive branch with three paths under a single Trigger.
  • Row 1: “Condition_1Condition + Set Color”
    Corresponds to if (Condition_1)Condition) { SetColor(); }.
    Set Color runs only when Condition_1Condition is true.
  • Row 2: “Condition_2 + Set Color_1”Color”
    Corresponds to else if (Condition_2) { SetColor_1(SetColor(); }.
    Set Color_1Color runs only when Condition_1Condition is false and Condition_2 is true.
  • Row 3: “Else + Set Text”Image”
    Corresponds to else { SetText(SetImage(); }.
    Set Text runs only when both Condition_1Condition and Condition_2 are false.
The key point is that exactly one Action runs: evaluation proceeds top to bottom and executes the Action on the first row whose condition matches.
if (Check Click)
        Set Color();
    else
        Set Text(Image();
Case 7: Nested if (After-based layout)
This configuration represents a nested if where one Condition BlockConditionOutput is evaluated only inside the branch of another.
  • The flow goes from the Trigger Check Click to Condition_1Condition—this is the outer if (CheckClick).
  • The row “Condition_1Condition + Set Color” corresponds to if (Condition_1)Condition) { SetColor(); … }.
  • Because there is a connector from Set Color down to Condition_2, Condition_2 is evaluated only when Condition_1Condition is true. If Condition_1Condition is false, the flow does not proceed to Condition_2.
  • The lower row “Condition_2 + Set Color_1”Color” corresponds to if (Condition_2) { SetColor_1(SetColor(); }. Thus, only when both Condition_1Condition and Condition_2 are true do SetColor() and then SetColor_1(SetColor() run in sequence.
  • After and After_2After_1 serve as visual exits/merge points for the Condition_1Condition block and the Condition_2 block, respectively.
In contrast to Case 4, where two Condition BlocksConditionOutputs are treated as two independent ifs that are both evaluated, Case 7 places Condition_2 entirely inside Condition_1Condition, forming a classic nested if structure.
if (Check Click)
        Set Color();
        if (Condition_2)
