Building Own Application for Linux with a Wayland Display Server
Generate Makefiles with CMake
    Open a terminal. Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    Important! From the same console with the set environment start the CMake GUI or run the CMake commandline. We will continue with the CMake GUI in this guide. Point CMake to source directory
    • Folder containing top-level "CMakeLists.txt", e.g. \cmake\Candera\/cmake/Candera/Player
    Point CMake to binary directory
    Configure
    • Specify “Unix Makefiles”Makefiles as generator for the projectproject.
    • Specify tool-chain file for cross-compilingcompiling.
    Select the toolchain-file from the delivery (adapt for your toolchain installation and application specific needs)
        /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Linux.txt
        OpenGL ES 2.0 and 3.0 versions are supported please configure CMake variable "CGIDEVICE_GLES_VERSION"
        Adapt the CMake settingssettings, if necessary, e.g.:
        • CMAKE_BUILD_TYPE-> Debug or ReleaseRelease.
        Enable/disable features. Press Configure. Press Generate.
        Building Application
        useMake samesure Terminalthat sessionthe environment variables for allthe steps.Yocto SDK are set in the terminal! Either reuse the terminal used to start CMake for building the Player or call the environment setup script again.
        $source
        /<path
          Initializeto the cross-compileYocto environmentSDK variables first have to be set with following command
          . /<path-to-yocto-installation>/environment-setup-...<platform specific suffix e.g. aarch64-poky-linux>
          1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
          2. After generating your cmake files, simply navigate to the specified build directory (binary directory created in CMake GUI) and type "make" within terminal to start the build process.or “make -j” to build with multithreading.
          For CourierSampleApp and CitDemoApp asset file have tomust be created with theira ownmatching SCHost.dll as the SCHost.dll for the CourierSampleApp and CitDemoApp contain specialized Widgets.
