Building Own Application for Linux with a Wayland Display Server
Generate Makefiles with CMake
  1. Open a terminal.
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    • Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
  6. Configure
    • Specify Unix Makefiles as generator for the project.
    • Specify tool-chain file for cross-compiling.
    /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Linux.txt
    If Vulkan support is required, use the Vulkan-specific toolchain file.
    /cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Vulkan-Linux.txt
  8. Adapt the CMake settings, if necessary, e.g.:
    • CMAKE_BUILD_TYPE-> Debug or Release.
    • Enable/disable features.
    • Press Configure.
  9. Press Generate.
Building Application
  1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
Vulkan Packaging Workflow
After a successful Vulkan build:
  1. Build and copy ANGLE Vulkan Libraries:
    Build your own ANGLE Vulkan libraries for your target platform:
    - libEGL.so
    - libGLESv2.so
    These libraries must match your target architecture.
    Copy into the same directory where the Player executable is located (the build output directory).
  2. Run Packaging Script
    From the build directory, execute the `package_player.sh`sh script. After execution, a folder named **vulkan**vulkan will be created.
    Inside this folder you will find **Player.run**run this is the only required output package.
  3. Run the packaged Player using `./Player.run Your_Asset.bin`bin
