Building Own Application for Linux with a Wayland Display Server
Generate Makefiles with CMake
- Open a terminal.
- Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
$source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux> - Important! From the same console with the set environment start the CMake GUI or run the CMake commandline. We will continue with the CMake GUI in this guide.
- Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
- Configure
- Specify Unix Makefiles as generator for the project.
- Specify tool-chain file for cross-compiling.
/cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Linux.txtIf Vulkan support is required, use the Vulkan-specific toolchain file.
/cgi_studio_devices/src/Wayland/ToolchainFiles/GCC-toolchain-Wayland-Vulkan-Linux.txt - Adapt the CMake settings, if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release.
- Enable/disable features.
- Press Configure.
- Press Generate.
Building Application
- Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
- After generating your cmake files, navigate to the specified build directory (binary directory created in CMake GUI) and type "make" to start the build or “make -j” to build with multithreading.
Vulkan Packaging Workflow
After a successful Vulkan build:
- Build and copy ANGLE Vulkan Libraries:
Build your own ANGLE Vulkan libraries for your target platform:
- libEGL.so
- libGLESv2.so
These libraries must match your target architecture.
Copy into the same directory where the Player executable is located (the build output directory).
- Run Packaging Script
From the build directory, execute the `package_player.sh` script. After execution, a folder named **vulkan** will be created.
Inside this folder you will find **Player.run** this is the only required output package. - Run the packaged Player using `./Player.run Your_Asset.bin`
