JPEG Decoder Behavior
Feature Description
Supported Platforms
Limitations
  • Check the JPEG Bitmap Converter documentation for the supported pixel formats.
If the JPEG Decoder Behavior is being used, ensure that the JPEG Decoder feature has been enabled in the CMAKE options. While generating the project for target, turn on the CMAKE flag CGIDEVICE_TRAVEO2_JPEG_DECODER_ENABLED or add this flag to the toolchain file.
A blue line on a white background  AI-generated content may be incorrect.
How to use the JPEG Decoder
    b. Step 2: Paste the Candera Name into the ResourceCanderaName property of the JPEG Decoder Behavior in the Properties panel.
  5. Enable/Disable the Decoder: You can toggle the decoder using the enabled property.
