JPEG Decoder Behavior
Feature Description
Supported Platforms
Limitations
  • Single Image Decoding: Only one image can be decoded at a time.
  • Baseline JPEG with RGB Encoding: The JPEG decoder behavior only supports baseline JPEG images encoded in RGB format.
  • Scene Editor cannot display the decoded image: The Scene Editor currently cannot display the decoded image; it is only viewable on the hardware.
How to use the JPEG Decoder
    b. Step 2: Paste the Candera Name into the ResourceCanderaName property of the JPEG Decoder Behavior in the Properties panel.
  5. Enable/Disable the Decoder: You can toggle the decoder using the enabled property.
Choosing the correct toolchain file for cross-compilation
If the JPEG decoder feature is being used, ensure that the correct toolchain file has been used. Toolchain files are available in the directory cgi_studio_devices\src\Traveo2\ToolchainFiles
Use one of the following two toolchain files with the suffix _JPEG if using the JPEG decoder behavior so that the linker file dedicates a section for the JPEG Decoder output.
  • MULTI-toolchain-Traveo2_C_6M_JPEG.txt
  • MULTI-toolchain-Traveo2_C_6MDDR_JPEG.txt
If the JPEG decoder is not being used, use the toolchain files that do not have the _JPEG suffix.
Changes in the linker_directives.ld file
The following two lines present in linker directives file create a jpeg decode buffer section to which the JPEG decoder will write the decoded image.
.jpeg_decode_buffer_base ALIGN(1) : > .
.jpeg_decode_buffer ALIGN(1) PAD(1M) : > . // JPEG decoder output
The size of the section and the location can be changed according to the target for which the application is being built.
For example, in the 6m DDR board, the location of the jpeg_decode_buffer section can be inside the LPDDR4_RAM area, however for the 6m board, it would have to be in either SRAM or VRAM (preferred).
Example for 6m board
Example for 6m DDR board
Converting images to supported format
To ensure compatibility, you may need to convert your JPEG images to an RGB-encoded baseline JPEG format. Follow the steps below to install the necessary tools and use the conversion script.
Software Requirements
The conversion script uses djpeg and cjpeg utilities, which are part of the libjpeg-turbo software. You need to install them and make them accessible via your system’s PATH environment variable.
Installation Steps
  1. Download libjpeg-turbo from this link (libjpeg-turbo).
  2. Extract the downloaded files, install the exe and locate libjpeg-turbo-gcc64\bin.
  3. Since libjpeg-turbo includes the necessary executables, its bin folder path must be added to the system's Environment Variables.
  4. Add the folder path to your system’s Environment Variables:
    a. Open System Properties > Environment Variables.
    b. Under System Variables, find and edit the Path variable.
    c. Add the path to libjpeg-turbo-gcc64\bin.
Using the Conversion Script
The provided batch script, encode_jpeg_as_rgb.bat, automates the conversion of YCbCr JPEGs into RGB-encoded JPEGs. You simply drag and drop a JPEG file onto the script, and it processes the image automatically.
Steps for Conversion
  1. Ensure libjpeg-turbo is installed and is accessible in PATH.
  2. Place the batch script in a directory where your images are stored. (Code for the script is given at the end of this document)
  3. Drag and drop a JPEG file onto the script.
  4. The script will generate a new file with _rgb appended to the filename.
Example Usage
  • Input: sample.jpg (YCbCr format)
  • Output: sample_rgb.jpg (RGB format)
  • After running the script, the folder will look like this, with the converted images having '_rgb' appended to their filenames.
Verifying the Converted Images
To check if the image needs conversion, the following method can be used:
  1. Install ffmpeg from the link: Download FFmpeg
  2. Ensure the ffprobe command can be run on terminal by adding the path to the ffmpeg bin folder into the system PATH environment variable.
  3. Open a terminal in the folder where the image is located and run the command “ffprobe image_name.jpg”.
  4. Ensure that the format of the image as displayed by the ffprobe command is (Baseline), gbrp.
Even when run on single images, the ffprobe command will show the type as mjpeg.
Conversion Script
Paste the following code into a .bat file to create the conversion script.
@echo off
setlocal
:: Check if a file is dragged and dropped
if "%~1"=="" (
    echo Usage: Drag and drop a JPEG file onto this script to convert it.
    echo.
    echo The output file will be saved with "_rgb" appended to the input file name.
    goto end
:: Set the input file path
set INPUT_FILE=%~1
:: Check if the input file exists
if not exist "%INPUT_FILE%" (
    echo Error: Input file "%INPUT_FILE%" not found.
    goto end
:: Generate the output file name with "_rgb" suffix
:: Temporary PPM file
set TEMP_PPM="%TEMP%\temp.ppm"
:: Step 1: Convert input JPEG to PPM using djpeg
echo Converting input JPEG to PPM...
djpeg -outfile %TEMP_PPM% "%INPUT_FILE%"
if errorlevel 1 (
    echo Error: Failed to convert input JPEG to PPM.
    goto end
:: Step 2: Convert PPM to RGB-encoded JPEG using cjpeg
echo Converting PPM to RGB-encoded JPEG...
cjpeg -rgb -outfile "%OUTPUT_FILE%" %TEMP_PPM%
if errorlevel 1 (
    echo Error: Failed to convert PPM to RGB-encoded JPEG.
    goto end
:: Clean up temporary PPM file
del %TEMP_PPM%
echo Conversion successful!
echo Output saved to "%OUTPUT_FILE%"
goto end
:end
endlocal@echo off
setlocal
if "%~1"=="" (
    echo.
    goto end
set INPUT_FILE=%~1
    goto end
if errorlevel 1 (
    goto end
if errorlevel 1 (
    goto end
del %TEMP_PPM%
goto end
:end
endlocal
