JPEG Decoder Behavior
Feature Description
Supported Platforms
Limitations
How to use the JPEG Decoder
Add the Bitmap node to the scene: Add a bitmap node to a 2D scene. Add the Behavior to a Bitmap Node: Place the JPEG Decoder behavior onto a Bitmap Node in the scene.
Set the Resource Candera Name: Paste the Candera Name of the raw JPEG image into the Resource Candera Name property using the steps below.
b. Step 2: Paste the Candera Name into the ResourceCanderaName property of the JPEG Decoder Behavior in the Properties panel.
Enable/Disable the Decoder: You can toggle the decoder using the enabled property.
Changes required in the toolchain file
The path to the Infineon Traveo 2 JPEG decoder driver must be added to the toolchain file since the JPEG Decoder behavior uses this driver to decode the JPEG images. Add the following line to the cross-compilation toolchain file:
set(CGIDEVICE_TARGET_TRAVEO2_JPEG_DRIVER_PATH "path\to\jpeg\decoder\driver\root" CACHE PATH "Root path to the Traveo2 JPEG decoder driver.")
Ensure the following folders are available in the driver root path:
Building the JPEG Decoder Driver from source (if available)
In case the JPEG decoder driver binaries are not available, it can be built from source as well, if available, following the steps given below.
The JPEG Decoder driver can only be built in production environment, however, if the base application is being built in release or debug environment, copies of the Bin/arm-none-ghs/production folder can be created and renamed to release or debug as required.
Converting images to supported format
To ensure compatibility, you may need to convert your JPEG images to an RGB-encoded baseline JPEG format. Follow the steps below to install the necessary tools and use the conversion script.
Software Requirements
The conversion script uses djpeg and cjpeg utilities, which are part of the libjpeg-turbo software. You need to install them and make them accessible via your system’s PATH environment variable.
Installation Steps
a. Open System Properties > Environment Variables.
b. Under System Variables, find and edit the Path variable.
c. Add the path to libjpeg-turbo-gcc64\bin.
Using the Conversion Script
The provided batch script, encode_jpeg_as_rgb.bat, automates the conversion of YCbCr JPEGs into RGB-encoded JPEGs. You simply drag and drop a JPEG file onto the script, and it processes the image automatically.
Steps for Conversion
Place the batch script in a directory where your images are stored.
Drag and drop a JPEG file onto the script.
The script will generate a new file with _rgb appended to the filename.
Example Usage
Output: sample_rgb.jpg (RGB format)
After running the script, the folder will look like this, with the converted images having '_rgb' appended to their filenames.
Verifying the Converted Images
To check if the image needs conversion, the following method can be used:
Ensure the ffprobe command can be run on terminal by adding the path to the ffmpeg bin folder into the system PATH environment variable.
Open a terminal in the folder where the image is located and run the command “ffprobe image_name.jpg”.
Ensure that the format of the image as displayed by the ffprobe command is (Baseline), gbrp.
Even when run on single images, the ffprobe command will show the type as mjpeg.
