STM32MP157 Target Setup Guide
Before you Begin
  • Explore CGI-Studio
    Watch the Video Tutorials and read the Quick Start Guide.
  •  Generate Assets for Simulation and Target Environments
Software Image Setup
Please note, that this chapter contains links to an external resource (e.g. ST image and wiki). These links were used by Candera for this guide in December 2024 and might have changed inFlashing the meanwhile.Target Device
Download the official ST targetprepared image fromprovided here:by Candera:
STM32MP1Starter - STM32MP1 OpenSTLinux Starter Package - STMicroelectronics
ST Image version 3.1.0 must be used for the CGI Professional Edition 3.15 due some API changes in ST image version 4+.FlashLayout_sdcard_stm32mp157f-dk2-opteemin.raw
To
Forflash the image andto hardwarea setupmicro pleaseSD followcard with minimum size of 8GB, use a tool such as Etcher.io. After the officialflashing STprocess guide:
STM32MP15is complete, insert the SD card into the STM32MP157 Discovery kitsKit, -then Starterpower Packageon -the stm32mpudevice to boot from the SD card.
Please check that your boot settings are correctly set to boot from the SD card according to the official guide.
PleaseAfter bebooting, awareconnect ofto the target device via a serial terminal (e.g. Tera Term) or SSH and run the following potentialsetup issuesscript whileto followingcomplete the setupinstallation guide.
    During image flashing make sure to use the correct extensible FlashLayout file, specific to your hardware.
    STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/extensible/FlashLayout_sdcard_stm32mp157x-dk2-extensible.tsv
    During the flashing process, we encountered an issue thatof required us to copy specific filespackages and foldersconfiguration: from
    cd the/opt/cgistudio/PlayerConnector
    extracted./install.sh
    stm32mp1.tar archive into the flashlayout_st-image-weston/extensible folder. The following files and folders from the root folder (images\stm32mp1) were necessary in the extensible folder for successful SD card flashing:
    |- arm-trusted-firmware
    |- fip
    - st-image-bootfs-openstlinux-weston-stm32mp1.ext4
    - st-image-userfs-openstlinux-weston-stm32mp1.ext4
    - st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
    - st-image-weston-openstlinux-weston-stm32mp1.ext4
    After following the official setup, you should have a running target device with a terminal connection. This is required for the next steps. For the Python installation (needed for Python-based data binding) it is required to connect the target to the internet.
    At Candera we have used Tera TermWinSCP for the remote serial terminal connection and WinSCP for theto transfer ofadditional files to the target device.device as needed.
    After this step, your target system will be prepared to run Python-based data binding examples or any assets using the CGI-Studio runtime environment.
    To change the location of the Weston taskbar (which is positioned at the bottom by default) or to remove it entirely you can use our set_weston_panel.sh script located in /opt/cgistudio/PlayerConnector/set_weston_panel.sh.
    Blood Pressure Sample
    We have prepared several samples to demonstrate the capabilities of CGI-Studio on the target image. These samples are located at:
    /opt/cgistudio/PlayerConnector/Samples/ on the target image and in <cgi-studio-installation-path>\bin\Player\PlayerConnector\Samples on the host computer.
    We will use the Blood Pressure Sample as an example to demonstrate how to run our samples. The Blood Pressure device sample is a Scene Composer sample that demonstratesshowcases a blood pressure measurement device with exemplary scenes and animations.
    In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Player Connector Library.
    For this chapter the completed “Image Setup” is required, and it is assumed that WinSCP is downloaded and installed.
    required.
    • ConnectNavigate to the targetPlayer device with WinSCP. directory
      Launch WinSCP, in the host name field enter the IP address of the target device, and for the username use“root”. Default values should be used for the remaining fields.
      ReferNavigate to the ST Setup Guide for information on obtaining the device’s IP address.
    Transfer Files to the Target
    Use WinSCP to transfer the following files to the target device:
      Target Player executable:
      <cgi-installation-path>/bin/Player/TargetPlayer/Player
      Solution asset binary file: The asset binary you wish to run.
      <cgi-installation-path>/bin/Player/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
      Set Execution Permissions
      To set execution permissionsdirectory before running the asset in the target player, execute the following command in the remote terminal.asset:
      chmodcd +x Player/opt/cgistudio/TargetPlayer
      Run the Asset
      ./Player ../PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
      In this section, we explain how to execute the Blood Pressure sample including Python-based data binding with our Player Connector Library and how to install the required software on the target.Library. The Player Connector Library allows the simple connection between CGI Studio Player and a Python-based script.
      Please note that the “Blood Pressure sample with Python” has been prepared for integration with the Soundhound voice recognition service. For the sake of simplicity in this guide, we will not use this service. By running the sample, you will be presented with a start scene waiting for voice input. As the voice recognition service is not configured, it will not perform any action. To continue using the sample, simply press 'Start'.
      For guidance on configuring the voice recognition service by utilizing our Soundhound integration, please refer to our CGI-Studio Documentation: Blood Pressure Sample
      Python Installation
      Python is required for the Player Connector Library, to enable Python-based data binding for CGI-Studio. The target device needs to have an internet connection for installing python.
      This section only covers the Python installation on the target device. In the host environment Python can be installed with the help of the python download guide on the Python webpage. We have used Python version 3.12.6, but the latest version is supported.
      To install Python on the target device, follow these steps on the target:
        Update Packages and Install Python.
        Run the following commands on the target device with remote terminal:
        apt-get update && apt-get upgrade
        apt-get install python3
        If pip is not installed by default run
        python3 -m ensurepip –-upgrade
        Verify the installation of pip3 by using the command “pip3”.
        Python Script
        Before we proceed with executing the script, let's first take a moment to review the key components of the Player Connector Library script, which can be found at the following location:location on your host computer:
        This script can also be found in /opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice.py on the image.
        1. Import the Player Connector Library and additional required libraries.
          import argparse
          import time
          import signal
          from SoundhoundCommandClient import SoundhoundCommandClient
        2. Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
          #Looping until sig int
          try:
            while not sigintCaptured:
            App.Step()
          normalizedProgress * 100.0)
          except KeyboardInterrupt:
          finally:
            App.ShutDown()
            if SoundhoundCommandClient is not None:
          exit()
        Run Blood Pressure Sample with Player Connector Library in Simulation Environment (Host)
        To run the Python-based data binding in the simulation environment (on the host computer) execute the steps below on the host computer:
        Please make sure to create a clean copy of the <cgi-studio-installation-path>\bin\Player\PlayerConnector folder before creating the Python environment, since this folder is required in its original form for the target.
          Create and activate a Python environment:
          It is recommended to create your own Python environment to keep dependencies isolated. To do this, run in the command line:
          python -m venv .
          Script\activate
          Install libraries:
          In order to install the Player Connector Library and other required libraries you need to executeexecute:
          pip install -r requirements.requirementsWithoutSoundhound.txt
          Run Blood Pressure Sample Simulation Asset with Python-based Data Binding
          By running the sample, you will be presented with a start scene waiting for voiceyour input. As the voice recognition service is not configured, it will not perform any action. To continue using the sample, simply press the 'Start'. button on the player.
          Please note that the -wsh parameter is only necessary for the Blood Pressure Sample and not for the Slider and Gauge sample script.
          python BloodPressureDevice.py -wsh -lbp  ..\..\PlayerConnectorLibrary.dll -abp BloodPressureSample_Simulation.bin
          Run Blood Pressure Sample with Player Connector Library in Target Environment
          It’s assumed that a remote terminal (Tera Term) and WinSCP connection is established.
          established and the setup script /opt/cgistudio/PlayerConnector/install.sh was executed successfully.
            Copy required files
            Copy the listed folder to the target using using WinSCP.
              Player Connector Library: <cgi-studio-installation-path>/bin/Player/PlayerConnector (all files from this folder are necessary)
              Navigate to the BloodPressureDevice folder
              cd <path-to-PlayerConnector-folder>/opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice
              Create and Activate a Python environment:
              It is recommended to create and activate a Python environment by running the following in the remote console:
              python3 -m venv .
              source bin/activate
              Install libraries:
              In order to install the PlayerConnector Library and additional required libraries on the target run this command
              pip3 install -r requirements.txt
              Run asset with Python-based Data Binding
              By running the sample, you will be presented with a start scene waiting for voiceyour input. As the voice recognition service is not configured, it will not perform any action. To continue using the sample, simply press 'Start'. button on the target screen.
              python3 BloodPressureDevice.py -wsh -lbp ../../libPlayerConnectorLibrary.so -abp BloodPressureSample_Target.BloodPressureDevice_Target.bin
              This chapter shows how you can create your own solution with Python data binding on host and target withthrough a simple use case.case, and how to run it on host and target. It is using a Gauge Control for HMI data output for the user and a Slider Control for HMI data input via user.
              Before proceeding with the example, it is recommended to explore CGI-Studio by viewing the Video Tutorials and the Quick Start Guide, both of which are available in the CGI-Studio DocumentationDocumentation.
              • Start Scene Composer in <cgi-studio-installation-path>\bin\SceneComposer\Scenecomposer.exe
                <cgi-installation-path>\bin\Player\PlayerConnector\Samples\SliderAndGauge\Sample.py.py in your local CGI-Studio installation folder and in /opt/cgistudio/PlayerConnector/Samples/SliderAndGauge/Sample.py on the target image.
                Do it analogous to the steps from chapter Run AssetBlood Pressure Sample with Player Connector Library in Simulation Environment (Host).
                Important: aA requirements.txt file is not necessary, since only the Player Connector Library needs to be installed:
                (ensureEnsure the device is set up correctly,correctly followingaccording to the officialchapter guide)Software Image Setup. Use WinSCP or a similar tool to copy the generated target asset from the host computer to the target device.
                DoRun it analogous to the steps from chapter Run AssetBlood Pressure Sample with Player Connector Library in Target Environment.
                Important: Only the Player Connector Library needs to be installed on the target:
                pip3 install <path-to-player-connector-folder>
              Final comments
