STM32MP157 Target Setup Guide
Before you Begin
  • Explore CGI-Studio
    Watch the Video Tutorials and read the Quick Start Guide.
Software Image Setup
Flashing the Target Device
Download the prepared image provided by Candera:
FlashLayout_sdcard_stm32mp157f-dk2-opteemin.raw
To flash the image to a micro SD card with minimum size of 8GB, use a tool such as Etcher.io. After the flashing process is complete, insert the SD card into the STM32MP157 Discovery Kit, then power on the device to boot from the SD card.
Please check that your boot settings are correctly set to boot from the SD card according to the official guide.
After booting, connect to the target device via a serial terminal (e.g. Tera Term) or SSH and run the following setup script to complete the installation of required packages and configuration:
cd /opt/cgistudio/PlayerConnector
./install.sh
At Candera we have used WinSCP to transfer additional files to the target device as needed.
After this step, your target system will be prepared to run Python-based data binding examples or any assets using the CGI-Studio runtime environment.
To change the location of the Weston taskbar (which is positioned at the bottom by default) or to remove it entirely you can use our set_weston_panel.sh script located in /opt/cgistudio/PlayerConnector/set_weston_panel.sh.
Blood Pressure Sample
We have prepared several samples to demonstrate the capabilities of CGI-Studio on the target image. These samples are located at:
/opt/cgistudio/PlayerConnector/Samples/ on the target image and in <cgi-studio-installation-path>\bin\ProfessionalEdition\Wayland_STM32MP157_Simulation\PlayerConnector\Python\Samples on the host computer.
We will use the Blood Pressure Sample as an example to demonstrate how to run our samples. The Blood Pressure device sample is a Scene Composer sample that showcases a blood pressure measurement device with exemplary scenes and animations.
In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Player Connector Library. For this chapter the completed “Image Setup” is required.
  • Navigate to the Player directory
    Navigate to the Player directory before running the asset:
    cd /opt/cgistudio/TargetPlayer
  • Run the Asset
    ./Player ../PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
In this section, we explain how to execute the Blood Pressure sample including Python-based data binding with our Player Connector Library. The Player Connector Library allows the simple connection between CGI Studio Player and a Python-based script.
Python Script
Before we proceed with executing the script, let's first take a moment to review the key components of the Player Connector Library script, which can be found at the following location on your host computer:
<cgi-studio-installation-path>\bin\ProfessionalEdition\Wayland_STM32MP157_Simulation\PlayerConnector\Python\Samples\BloodPressureDevice\BloodPressureDevice.py
This script can also be found in /opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice.py on the image.
  1. Import the Player Connector Library and additional required libraries.
    import argparse
    import time
    import signal
  2. Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
    #Looping until sig int
    try:
      while not sigintCaptured:
      App.Step()
    normalizedProgress * 100.0)
    except KeyboardInterrupt:
    finally:
      App.ShutDown()
      if SoundhoundCommandClient is not None:
    exit()
Run Blood Pressure Sample with Player Connector Library in Simulation Environment (Host)
To run the Python-based data binding in the simulation environment (on the host computer) execute the steps below on the host computer:
  • Install libraries:
    In order to install the Player Connector Library and other required libraries you need to execute:
    pip install -r requirementsWithoutSoundhound.txt
    By running the sample, you will be presented with a start scene waiting for your input. To continue using the sample, simply press the 'Start' button on the player.
    Please note that the -wsh parameter is only necessary for the Blood Pressure Sample and not for the Slider and Gauge sample script.
    pythonpy BloodPressureDevice.py -wsh -lbp ..\..\..\STM32MP157_Simulation\PlayerConnector\PlayerConnectorLibrary.dll -abp BloodPressureSample_Simulation.bin
Run Blood Pressure Sample with Player Connector Library in Target Environment
It’s assumed that a remote terminal (Tera Term) connection is established and the setup script /opt/cgistudio/PlayerConnector/install.sh was executed successfully.
    cd /opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice
    By running the sample, you will be presented with a start scene waiting for your input. To continue using the sample, simply press 'Start' button on the target screen.
    python3 BloodPressureDevice.py -wsh -lbp ../../libPlayerConnectorLibrary.so -abp BloodPressureDevice_Target.bin
Before proceeding with the example, it is recommended to explore CGI-Studio by viewing the Video Tutorials and the Quick Start Guide, both of which are available in the CGI-Studio Documentation.
  • Start Scene Composer in <cgi-studio-installation-path>\bin\SceneComposer\Scenecomposer.exe
    <cgi-installation-path>\bin\ProfessionalEdition\Wayland_STM32MP157_Simulation\PlayerConnector\Pythony\Samples\SliderAndGauge\Sample.py in your local CGI-Studio installation folder and in /opt/cgistudio/PlayerConnector/Samples/SliderAndGauge/Sample.py on the target image.
    Do it analogous to the steps from chapter Run Blood Pressure Sample with Player Connector Library in Simulation Environment (Host).
    A requirements.txt file is not necessary, since only the Player Connector Library needs to be installed:
    Run it analogous to the steps from chapter Run Blood Pressure Sample with Player Connector Library in Target Environment.
Final comments
