Target Setup for the STM32MP135f and other Linux based targets
This guide aims to explain how to setup a Linux based target for the Software Renderer Platform and how to build a player for this target. The guide was tested on the STM32MP135f but the setup should be similar on most other Linux platforms that support DRM/KMS.
Before you Begin
- Explore CGI-Studio
Watch the Video Tutorials and read the Quick Start Guide. - Learn to create SceneComposer Solutions
Target and build setup
To setup the ST32MP135f-DK follow the guide provided by STM: Populate the target and boot the image - stm32mpu
To setup the SDK (inside a WSL or Linux host PC) to build a player for the STM32 follow this guide provided by STM: Install the SDK - stm32mpu
Building the Player
tested inside an Ubuntu WSL:
- source the SDK like described in the Install the SDK Guide from STM
- inside the root directory of cgi trunk:
- mkdir build && cd build
- cmake -DCMAKE_TOOLCHAIN_FILE="../cgi_studio_devices/src/SoftwareRenderer2D/ToolchainFiles/GCC-toolchain-STM32MP135f-DrmKms-Linux.txt -DCGIDEVICE_EVDEV_INPUT_ENABLED=ON ../cmake/Candera/Player/ && make -j
The Player should now be build and can be uploaded to the Target.
Uploading Player and Asset file to the target
- Connect an USB-C Cable to CN7 USB-C of the target to the host pc
- Connect USB-C Power cable to the PWR USB-C port
- After the device boots a ssh connection can be established to the device:
- ssh root@192.168.7.162 #the ip adress
- It might be necessary to kill weston if it is still running. It NEEDS to be killed otherwise there will be a conflict with the Player over display access
- Copy the compiled player and in Scene Composer generated Asset.bin file to the target (using WinScp or scp) and run them like so:
- ./Player Asset.bin
