Target Setup for the STM32MP135f and other Linux based targets
This guide aims to explain how to setup a Linux based target for the Software Renderer Platform and how to build a player for this target. The guide was tested on the STM32MP135f but the setup should be similar on most other Linux platforms that support DRM/KMS.
Before you begin
  • Explore CGI-Studio
    Read the Quick Start Guide.
Target and build setup
For setup of the ST32MP135f-DK follow the guide provided by STM: Populate the target and boot the image - stm32mpu
For setup of the SDK (inside a WSL or Linux host PC) to build a player for the STM32 follow this guide provided by STM: Install the SDK - stm32mpu
Building the Player
tested inside an Ubuntu WSL:
  1. source the SDK like described in the Install the SDK Guide from STM
  2.  within the root directory of cgi trunk:
    1. mkdir build && cd build
    2. cmake -DCMAKE_TOOLCHAIN_FILE="../cgi_studio_devices/src/SoftwareRenderer2D/ToolchainFiles/GCC-toolchain-STM32MP135f-DrmKms-Linux.txt" -DCGIDEVICE_EVDEV_INPUT_ENABLED=ON ../cmake/Candera/Player/ && make -j
The Player should now be built and can be uploaded to the Target.
Uploading Player and Asset file to the target
  1. Connect an USB-C Cable to CN7 USB-C of the target to the host pc
  2. Connect USB-C Power cable to the PWR USB-C port
  3. After the device boots a ssh connection can be established to the device:
    1. ssh root@192.168.7.162 #the static ip address of the target
    2. It might be necessary to kill weston if it is still running. It NEEDS to be killed otherwise there will be a conflict with the Player over display access
  4. Copy the compiled player and in Scene Composer generated Asset.bin file to the target (using WinScp or scp) and run them like so:
    1. ./Player Asset.bin
