Fbdev: Prerequisites
Hardware: Telechips Dolphin 5
CGI Studio has been tested on Telechips Dolphin 5 Board.
CMake
Linux Toolchain (BSP)
- poky-telechips-systemd 4.0.17
- Image and SDK were prepared by the Candera.
- The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
- Compiler/s used for this release is GCC (GNU 11.2.1).
Hardware: Allwinner T507
CGI Studio has been tested on Allwinner T507 Board.
CMake
- To build the Player for the target platform, you need to download the additional library package: OKT507-linux-sdk20.tar.bz2
- The build requires an older version of Debian or Ubuntu. In our case, the entire build was performed on Ubuntu 18.04.6 LTS running in WSL on Windows 11.
export SDKTARGETSYSROOT=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot
export PATH=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH
- Compiler/s used for this release is GCC 5.3.1 (Linaro GCC 5.3-2016.05).
