Fbdev: Prerequisites
Hardware: Telechips Dolphin 5
CGI Studio has been tested on Telechips Dolphin 5 Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned here.
Linux Toolchain (BSP)
  • poky-telechips-systemd 4.0.17
  • Image and SDK were prepared by the Candera.
  • The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
  • Compiler/s used for this release is GCC (GNU 11.2.1).
Hardware: Allwinner T507
CGI Studio has been tested on Allwinner T507 Board.
CMake
  • To build the Player for the target platform, you need to download the additional library package: OKT507-linux-sdk20.tar.bz2
  • The build requires an older version of Debian or Ubuntu. In our case, the entire build was performed on Ubuntu 18.04.6 LTS running in WSL on Windows 11.
  • Compiler/s used for this release is GCC 5.3.1 (Linaro GCC 5.3-2016.05).
