Fbdev: Prerequisites
Hardware: Telechips Dolphin 5
CGI Studio has been tested on Telechips Dolphin 5 Board.
CMake
Linux Toolchain (BSP)
- poky-telechips-systemd 4.0.17
- Image and SDK were prepared by the Candera.
- The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
- Compiler/s used for this release is GCC (GNU 11.2.1).
Hardware: Allwinner T507
CGI Studio has been tested on Allwinner T507 Board.
CMake
export SDKTARGETSYSROOT=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot
export PATH=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH
The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer. Compiler/s used for this release is GCC (GNU 11.2.1).SD Card image, SDK and cross-compiler/s are not part of the delivery and have to be provided by the customer.
