Fbdev: Prerequisites
Hardware: Dolphin 5
CGI Studio has been tested on Telechips Dolphin 5 Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned here.
Linux Toolchain (BSP)
  • poky-telechips-systemd 4.0.17
  • Image and SDK were prepared by the Candera.
  • The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
  • Compiler/s used for this release is GCC (GNU 11.2.1).
