Target Setup and First Steps
Before you Begin
- Explore CGI-Studio
Software Image Setup
The CGI Studio Community Edition supports both Raspberry Pi 4 and Raspberry Pi 5. The following section describes how you can install the Community Edition on your Raspberry Pi device. Additional information about the proper setup and configuration of a Raspberry Pi device can be found in the official Raspberry Pi documentation. It also contains information on how to get started with your Raspberry Pi device. Complete the following steps to prepare your Raspberry Pi for the installation of the CGI Studio Community Edition.
- Download and install the Raspberry Pi Imager from this link: Raspberry Pi software – Raspberry Pi.
- Insert a compatible SD card into your computer for flashing the image.
- Open Raspberry Pi Imager and in the Device section select Raspberry Pi 4 or Raspberry Pi 5, depending on your model. Afterwards click "Next".
- In the menu Choose operating system select "Raspberry Pi OS (64-bit)". Then click "Next".
- In the storage section, select the inserted SD card, and click "Next".
- In the Customization step click "Next" till the "Customisation: SSH authentication" configuration occurs. Make sure that SSH is enabled.
- Click "Next" and write the image to the SD card. This may take some time.
- Finally eject the SD card from your PC.
Raspberry Pi Startup
- Insert the SD Card: Insert the flashed microSD card securely into the dedicated card slot on your Raspberry Pi board.
Connect Hardware: Connect your Raspberry Pi to an external display (using a micro-HDMI to HDMI cable), plug in your USB touch interface/peripherals or connect to DSI cable, and connect the official USB-C power supply to power it on.
- Initial Boot & Setup: The OS will automatically begin its initial boot diagnostics. Follow the on-screen configuration wizard to set up your region, skip the Wi-Fi and connect LAN, and establish your core username and password.
- Boot to Desktop: Once you complete the wizard, the system will finalize its settings and boot directly into the desktop user interface.
- Once installed, the OS UI will appear on the display.
Install Debian package on the Raspberry Pi
Installing this Debian (.deb) package configures the native CGI Studio Player application and the CGI Studio Player Connector on your Raspberry Pi. This chapter outlines the process of transferring and installing the CGI Studio Community package onto a Raspberry Pi 4 or Raspberry Pi 5 using WinSCP and a terminal connection.
- Transfer the File: Use WinSCP or SSH to transfer the downloaded
.debfile to your Raspberry Pi (e.g.,/home/username/). - Navigate to the Directory: Use
cdand verify withls. - Install the Package:
sudo apt update sudo apt install ./cgi-studio-community-rpi5_3.16.0-arm64.deb
The Blood Pressure Sample sample is extended with a data binding programmed in Python. The Python part of the sample relies on the Python-Based Player Data Binding Library to interact with the data bindings of the scene. Once the hardware is set up follow these steps to configure the Python environment and execute the sample.
- Move to the directory: Open the terminal on your Raspberry Pi and move to the sample directory.
cd /opt/candera/Python/Samples/BloodPressureDevice - Configure and activate the Python Virtual Environment:
Creating a virtual environment ensures that the dependencies for the Candera sample do not conflict with other system libraries.python -m venv . source bin/activate - Install Dependencies:
pip install -r ./requirementsWithoutSoundhound.txt -
Run the Sample:
- -wsh : Disable SoundHound integration
- -lbp : Library binary path
- -abp : Asset binary path
Verification: Upon execution, the Blood Pressure Device UI should initialize and appear on your connected Raspberry Pi display.python BloodPressureDevice.py -lbp /opt/candera/lib/libPlayerConnectorLibrary.so \ -abp /opt/candera/Python/Samples/BloodPressureDevice/BloodPressureDevice.bin -wsh
NOTE: If the display is portrait mode then it needs to be rotated to landscape mode.
Command -wlr-randr --output DSI-2 --transform 90
Before proceeding with the example, it is recommended to explore CGI-Studio by reading the Quick Start Guide, both of which are available in the CGI-Studio Documentation.
- Start Scene Composer in <cgi-studio-installation-path>\bin\SceneComposer\Scenecomposer.exe
- Open Empty Solution by either double clicking the empty solution thumbnail or through the File > New Solution dialog.
- In the Render Targets panel (on the right side of the SceneComposer), set the resolution of Display (0) to X Resolution (width) of 800 and Y Resolution (height) of 480.
- Drag and drop a Slider Control and a Gauge Control from the Control section of the Toolbox (on the right side of the Scene Composer) into the Scene Editor.
- You can move the controls in the Scene Editor by selecting the translation icon (the red square in the screenshot below) in the top left corner of the Scene Editor and then selecting the control which you want to move. Just select the item you want to move and drag it to a new location.
- Select the Gauge Control in either the Scene Editor or the Scene Tree, navigate to the properties, and adjust the scale to ensure it fits comfortably within the display.
- To set up a data binding for the Gauge value, first select the Gauge either in the Scene Editor or the Scene Tree. In the properties panel locate the Value property under the Control section and click the chain icon next to it to establish the binding.
A "Define Data Binding" window will appear. In this window, select Item1 (under PredefinedBindingSource1). Finally, click OK at the bottom to confirm your selection. - To set a data binding for the Slider property, select the Slider control in either the Scene Editor or the Scene Tree. Then, click the chain icon next to the Value property in the Control section of the Properties panel. Next, choose Item2 (under PredefinedBindingSource1) from the available options.
- Next, generate
twoan assetlibrarieslibrary forboththe target environment to run the solution in the player. - Next, create a Python script. You can use the provided Sample.py file located in
<cgi-installation-path>\bin\CommunityEdition\Pythony\Samples\SliderAndGauge\Sample.py in your local CGI-Studio installation folder and in /opt/cgistudio/Pyhton/Samples/SliderAndGauge/Sample.py on the target. - Run the asset on the target device:
Run it analogous to the steps from chapter Run Blood Pressure Sample with Player Connector Library.
