Target Setup Guide for RPi5
Before you Begin
- Explore CGI-Studio
Software Image Setup
The CGI Studio Community Edition supports both Raspberry Pi 4 and Raspberry Pi 5. The following section describes how you can install the Community Edition on your Raspberry Pi device.
- Download and install the Raspberry Pi Imager from this link: Raspberry Pi software – Raspberry Pi.
- Insert a compatible SD card into your computer for flashing the image.
- Open Raspberry Pi Imager and
clickin theChooseDeviceDevice.
Click
Flash OS on Raspberry Pi 5Startup
Flashing the operating system formats and configures your microSD card with the native Linux environment (Raspberry Pi OS Bookworm) required to run the Pi hardware. This guidesection outlines the initial hardware setup, booting, and first-time configuration process for provisioningsetting up the operating system on a Raspberry Pi 4 or a Raspberry Pi 5.
- Insert the SD Card: Insert the flashed microSD card securely into the dedicated card slot on your Raspberry Pi
5board. -
Connect Hardware: Connect your Raspberry Pi
5to an external display (using a micro-HDMI to HDMI cable), plug in your USB touch interface/peripherals or connect to DSI cable, and connect the official USB-C power supply to power it on. - Initial Boot & Setup: The OS will automatically begin its initial boot diagnostics. Follow the on-screen configuration wizard to set up your region, skip the Wi-Fi and connect LAN, and establish your core username and password.
- Boot to Desktop: Once you complete the wizard, the system will finalize its settings and boot directly into the desktop user interface.
- Once installed, the OS UI will appear on the display.
After booting, connect to the target device via a serial terminal (e.g., Tera Term) or SSH.
At Candera we used WinSCP to transfer additional files. After this step, your target system will be ready to run Python-based data binding examples or assets using the CGI-Studio runtime environment. Use the IP address of your Raspberry Pi device and your credentials for connecting with WinSCP.
Install DEB package on the RPi5
Installing this Debian (.deb) package configures the native CGI Studio Player application on your Raspberry Pi 5.Pi. This guide outlines the process of transferring and installing the CGI Studio Community package onto a Raspberry Pi 4 or Raspberry Pi 5 using WinSCP and thea terminal.terminal connection.
- Transfer the File: Use WinSCP to transfer the downloaded
.debfile to your Raspberry Pi (e.g.,/home/username/). - Navigate to the Directory: Use
cdand verify withls. - Install the Package:
sudo apt update sudo apt install ./cgi-studio-community-rpi5_3.16.0-arm64.deb
The bloodBlood pressurePressure deviceDevice sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations. General information on this sample can be found in the Blood Pressure Solution documentation.
FollowExecute the stepsfollowing belowcommand on the Raspberry Pi device to run the Bloodsample Pressureusing sample.our target player.
For the Community Edition, theThe sample wasis extended with a data binding sample programmed in Python. The Python part of the sample relies on the Python-Based Player Data Binding Library to interact with the data bindings of the scene. Once the hardware is set up follow these steps to configure the Python environment and execute the sample.
<cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\BloodPressureDevice on the host computer.computer and in /opt/candera/Python/Samples/BloodPressureDevice on the target, after successful installation of the debian package.
Follow the steps below to run the Blood Pressure sample with player connector library.
In Target open terminal and navigate to project directory
Open the terminal on your Raspberry Pi and move to the specific sample directory:Command -cd /opt/candera/Python/Samples/BloodPressureDevice
sudo apt update
sudo apt install python3-venvCreating a virtual environment ensures that the dependencies for the Candera sample do not conflict with other system libraries.
python3python -m venv .
source bin/activate
Install DependenciesInstall the required Python packages defined in the project's requirements file:
export PYTHONPATH=$PYTHONPATH:/opt/candera:/opt/candera/CanderaAppConnector:/opt/candera/Samples/BloodPressureDevice
export GST_PLUGIN_PATH=/usr/lib/aarch64-linux-gnu/gstreamer-1.0
export GSTREAMER_ROOT=/usr/lib/aarch64-linux-gnu/Execute the main script bywith pointingthese itflags:
-wsh the: PlayerDisable ConnectorSoundHound libraryintegration
-lbp the: compiledLibrary assetbinary file:path
-abp : Asset binary path
python3python BloodPressureDevice.py -wsh -lbp /opt/candera/PlayerConnector/lib/libPlayerConnectorLibrary.so -abp /opt/candera/Python/Samples/BloodPressureDevice/BloodPressureDevice.bin
Verification: Upon execution, the Blood Pressure Device UI should initialize and appear on your connected Raspberry Pi display.NOTE: If the display is portrait mode but if needs to be rotated to landscape mode.
Command -
wlr-randr --output DSI-2 --transform 90
