Reusable Solution Libraries
After selecting an SCL solution, a dialog will appear prompting you to choose a save path format.
However, if the path of the selected SCL solution is located within the Solution folder or the Scene Composer folder, it will automatically be saved as a relative path. In this case, the dialog explained in the below will not be shown.
In this dialog, you can select either a relative path or an absolute path. If you choose to use a relative path, you can further specify the reference base from the following two options:
Relative to Scene Composer
Relative to solution
TheIf availabilitythe ofselected SCL solution exists on the same drive, the relative path optionsoption dependswill onbe available, as shown in the figure above.
However, if the selected SCL solution meets any of the following conditions:
Conversionconversion to a relative path is possiblenot when all of the following conditions are met:
The target path is located on the same drive as the solution.
The target path is under the solution folder or the Scene Composer folder.
Conversion to a relative path is not possible if any of the following conditions apply.possible. In such cases, the dialog will only display the absolute"Absolute pathPath" option will be shown in the dialog.option:
The target path is located on a different drive (e.g., the solution is on drive C:
andwhile the target path is on drive D:).The target path is not
underlocated within thesolutionSolution folder or the Scene Composer folder.
- Inherited (the element, if it is a leaf, will inherit the property of the parent)
- Public (the element will be available as a reusable/shareable resource)
- Private (the element will not be available as a reusable/shareable resource)
