Reusable Solution Libraries
After selecting an SCL solution, a dialog will appear prompting you to choose a save path format.
In this dialog, you can select either a relative path or an absolute path. If you choose to use a relative path, you can further specify the reference base from the following two options:
Relative to Scene Composer
Relative to solution
The availability of the relative path options depends on the following conditions:
Conversion to a relative path is possible when all of the following conditions are met:
The target path is located on the same drive as the solution.
The target path is under the solution folder or the Scene Composer folder.
Conversion to a relative path is not possible if any of the following conditions apply. In such cases, only the absolute path option will be shown in the dialog.
The target path is located on a different drive (e.g., the solution is on drive C: and the target path is on drive D:)
The target path is not under the solution folder or the Scene Composer folder.
- Inherited (the element, if it is a leaf, will inherit the property of the parent)
- Public (the element will be available as a reusable/shareable resource)
- Private (the element will not be available as a reusable/shareable resource)
