Reusable Solution Libraries
Shareable component library (SCL) are not allowed to contain any display. If an already created solution does contain any display, the user will be noticed through a specific dialogue (see the image below).
After selecting an SCL solution, a dialog will appear prompting you to choose a save path format.
In this dialog, you can select either a relative path or an absolute path. If you choose to use a relative path, you can further specify the reference base from the following two options:
  • Relative to Scene Composer
  • Relative to solution
The availability of the relative path options depends on the following conditions:
Conditions for Display
Conversion to a relative path is possible when all of the following conditions are met:
  • The target path is located on the same drive as the solution.
  • The target path is under the solution folder or the Scene Composer folder.
Conditions for Hiding
Conversion to a relative path is not possible if any of the following conditions apply. In such cases, only the absolute path option will be shown in the dialog.
  • The target path is located on a different drive (e.g., the solution is on drive C: and the target path is on drive D:)
  • The target path is not under the solution folder or the Scene Composer folder.
  • Inherited (the element, if it is a leaf, will inherit the property of the parent)
  • Public (the element will be available as a reusable/shareable resource)
  • Private (the element will not be available as a reusable/shareable resource)
