Reusable Solution Libraries
Shareable component library (SCL) are not allowed to contain any display. If an already created solution does contain any display, the user will be noticed through a specific dialogue (see the image below).
  • Inherited (the element, if it is a leaf, will inherit the property of the parent)
  • Public (the element will be available as a reusable/shareable resource)
  • Private (the element will not be available as a reusable/shareable resource)
