Reusable Solution Libraries
For information on how to import an exported SCL file into your solution, please click here.
- Inherited (the element, if it is a leaf, will inherit the property of the parent)
- Public (the element will be available as a reusable/shareable resource)
- Private (the element will not be available as a reusable/shareable resource)
