Reusable Solution Libraries
Shareable component library (SCL) are not allowed to contain any display. If an already created solution does contain any display, the user will be noticed through a specific dialogue (see the image below).
After the export of the solution as a SCL solution, the content can be used in another solution after it is imported via "Solution Explorer" panel where a "References" node is available. When righ click on the "References" node, the "Add Reference" from the context menu allows the user to select the SCL solution.
  • Inherited (the element, if it is a leaf, will inherit the property of the parent)
  • Public (the element will be available as a reusable/shareable resource)
  • Private (the element will not be available as a reusable/shareable resource)
Using a Theme from SCL
If a SCL solution which contains a theme that is referenced, the user can use any template: Appearances, Bitmaps, Composites 3D, Composites 2D, Materials, Raw Resources, Render Modes, Textures, Uniform Setters. If the SCS solution contains a theme with the same name, the content of both themes will be merged.
When the user wants to add a new theme from a SCL solution he will first add the theme in the current solution by using the "Import" > "Import SCL Items" menu.
The "Import SCL Items" dialog offers the possibility to choose one of three possible options: "Create", "Ignore", "Ask Later".
In this case, the option "Create" will be chosen. If the "Ignore" option was previously selected, the dialog will never appear again. In all other cases the user will be required again to choose for a resolution each time when solution is opened.
An existing template can be used by drag and drop operation over a node in the Scene Tree panel. To use any of these types of templates from a theme contained in a referenced SCL solution, first, create a new theme. In this way all the available referenced templates will be visible in the "Themes" panel.
