New Solution
Create a New Solution
A new solution with all the basic elements can be created via Startup Panel item or menu "File" > "New Solution" or Toolbar item.
OnIn the first"New window,Solution" thedialog namethat appears after selecting one of the solution,above, theyou locationcan set basic information for your solution using two items: "Create new solution" and the"Solution Settings."
Create new solution
Name Solution name Solution Templates
Solution template canto be set.
    Select a templateuse for the solution from the select box "Solution template".
    (There are several templatesfor available,different e.g.purposes, Emptysuch Solution,as Empty, 2D BasicBasic, Solution,and 3D BasicBasic.)
    Solution
    ... Choose Platform Name
    Target platform
    Location
    Save the location whereof solution
    (Use the [Browse...] button to select the location to save the new solutionsolution.)
    will be saved using the "Browse" button. If no folder for the new solution has been created, make sure that checkbox "Create directory for solution"solution is checked.
    Create
    Confirma folder to save the creationnew ofsolution. Create with default State Machine
    Include a GlobalStateMachine in the solutionnew withsolution.
    "Finish" Is Shared Library
    Set it as a Shareable Component Library (SCL).
    (For more information on SCL, see Reusable Solution Libraries.)
    Solution Settings
    Width/Height Display/RenderTarget/2D Camera size Units Width/Height unit Pixels/Inch Resolution Clear Color Set the Clear Color. Color Depth Set the Color Depth.
    Once you have completed configuring the solution, click the [ Finish ] button to create the new solution.
    To configure more solution details at solution creation time, use the New Solution Wizard by clicking "Next >". insteadAbout ofdetails, "Finish"please refer to New Solution Wizard.
