New Solution
Create a New Solution
A new solution with all the basic elements can be created via Startup Panel item or menu "File" > "New Solution" or Toolbar item.
In the "New Solution" dialog that appears after selecting one of the above, you can set basic information for your solution using two items: "Create new solution" and "Solution Settings."
Create new solution
Name Solution name
Solution Templates
Solution template to use for the solution
(There are several for different purposes, such as Empty, 2D Basic, and 3D Basic.)
Platform Name
Target platform
Location
Save the location of solution
(Use the [Browse...] button to select the location to save the new solution.)
Create directory for solution
Create a folder to save the new solution.
Create with default State Machine
Include a GlobalStateMachine in the new solution.
Is Shared Library
Set it as a Shareable Component Library (SCL).
(For more information on SCL, see Reusable Solution Libraries.)
Solution Settings
Width/Height Display/RenderTarget/2D Camera size
Units Width/Height unit
Pixels/Inch Resolution
Clear Color Set the Clear Color.
Color Depth Set the Color Depth.
Once you have completed configuring the solution, click the [ Finish ] button to create the new solution.
To configure more solution details at solution creation time, use the New Solution Wizard by clicking "Next >". About details, please refer to New Solution Wizard.
