New Solution
Create a New Solution
A new solution with all the basic elements can be created via menu "File" > "New Solution" or Toolbar item.
On the first window, the name of the solution, the location and the template can be set.
- Select a template for the solution from the select box "Solution template". There are several templates available, e.g. Empty Solution, 2D Basic Solution, 3D Basic Solution ...
- Choose the location where the new solution will be saved using the "Browse" button.
- If no folder for the new solution has been created, make sure that checkbox "Create directory for solution" is checked.
- Confirm the creation of the solution with "Finish".
To configure more solution details at solution creation time, use the New Solution Wizard by clicking "Next >" instead of "Finish".
