Default Shader Config
For Shader Configuration in detail, see Shader Configuration.
During FBX import, no automatic shader assignment for the imported scene is performed. This means the imported nodes have no shader attachments in the node appearance, and rendering is done according to a default shader configuration as specified in the Default Shader Configuration dialog (See below image).
The default initial shader values for each 3D object type are shown in the table below.
| 3D Object Type | ShaderProgram | UniformSetter |
| Billboard | RefTrans_RefTex | TransShaderParamSetter |
| CanvasSpriteWithNoTexture | RefCanvasTrans_RefTex |
CanvasTransShaderParamSetter |
| CanvasSpriteWith1Texture | ||
| MeshWithNoTexture | RefTransLight1_RefColor | TransLightShaderParamSetter |
| MeshWith1Texture | RefTransLight1_RefColorTex | TransMorphingMeshTexShaderParamSetter |
| MorphingMeshWithNoTexture | RefTransLight1Morph_RefColor | TransMorphingMeshShaderParamSetter |
| MorphingMeshWith1Texture | RefTransLight1Morph_RefColorTex | TransMorphingMeshTexShaderParamSetter |
| PlanarShadow | RefTrans_RefUniDiffuseMat | TransUniDiffuseMatShaderParamSetter |
| PointSprite | RefTransPointSprite_RefPointSprite | TransPointSpriteShaderParamSetter |
| SkyBox | RefTransCubeMap_RefCubeMapTex | - |
| SkinningMeshWithNoTexture | RefTransLight1Skin_RefColor | TransLightShaderParamSetter |
| SkinningMeshWithTexture | RefTransLight1Skin_RefColorTex | |
| CanvasText | - |
- The initial value of SharedInstanceId is "0" for all types.
- In CanvasText, there is an AppearanceCollection, with an initial value of "CanvasText".
