Default Shader Config
For Shader Configuration in detail, see Shader Configuration.
During FBX import, no automatic shader assignment for the imported scene is performed. This means the imported nodes have no shader attachments in the node appearance, and rendering is done according to a default shader configuration as specified in the Default Shader Configuration dialog (See below image).
The default initial shader values for each 3D object type are shown in the table below.
3D Object Type ShaderProgram UniformSetter
Billboard RefTrans_RefTex TransShaderParamSetter
CanvasSpriteWithNoTexture RefCanvasTrans_RefTex
CanvasTransShaderParamSetter
CanvasSpriteWith1Texture
MeshWithNoTexture RefTransLight1_RefColor TransLightShaderParamSetter
MeshWith1Texture RefTransLight1_RefColorTex TransLightShaderParamSetter
MorphingMeshWithNoTexture RefTransLight1Morph_RefColor TransMorphingMeshShaderParamSetter
MorphingMeshWith1Texture RefTransLight1Morph_RefColorTex
PlanarShadow RefTrans_RefUniDiffuseMat TransUniDiffuseMatShaderParamSetter
PointSprite RefTransPointSprite_RefPointSprite TransPointSpriteShaderParamSetter
SkyBox RefTransCubeMap_RefCubeMapTex -
CanvasText - TransLightShaderParamSetter
  • The initial value of SharedInstanceId is "0" for all types.
  • In CanvasText, there is an AppearanceCollection, with an initial value of "CanvasText".
