SCML Tags > 3D Scene Tags
3D Scene Tags
Tag name Property Property type Supported Values/Types
Anchor AnchorDef String
Full name of the anchor definition from the composite which is used by this anchor node.
Transform Matrix4
Local generic transformation matrix multiplied with local position, scale and rotation. It can be used for transformations that can not be expressed using the component form.
Position Vector3
Position of the object in local coordinate space.
Rotation Vector3
Rotation of the object in local coordinate space.
Scale Vector3
Scale factor of the object in local coordinate space.
Center Vector3
The geometric center of the node. The center and the radius of an object describe a bounding sphere.
Radius Float Null
The radius of the bounding sphere, whereas the center defines the geometric center of the node.
BoxLowerLeftBackVertex Vector3
The minimum bounds vector of axis-aligned bounding box (lower left corner).
BoxUpperRightFrontVertex Vector3
The maximum bounds vector of axis-aligned bounding box (upper right corner).
IsIntersectionTestEnabled Boolean Null, True, False
Defines if intersection test is enabled in SceneComposer for picking and as well as at run-time. If disabled, the effective intersection test is disabled for all descendants as well.
RenderOrderBinName String
Name of the render order bin the node is assigned to. If no name is specified, the node is assigned automatically either to opaque or transparent render order bin, depending if node has blending enabled or not.
RenderOrderRank Int32 Null
Defines the render order rank. The node is sorted by rank if assigned to a dedicated render order bin with a RankOrderCriterion applied.
RenderBenchmark Float Null
Set the render measure value of this Node, which is a benchmark related to rendering time, typically calculated by external tool and utilized by a camera render strategy.
NodePreviewType NodePreviewType Null, Normal, Wireframe
Node preview type allows the user to change the representation of the solid objects in the SceneEditor. There are two modes available: normal (solid) and wireframe (line representation). Wireframe mode applies for meshes, morphing meshes, planar shadows and billboards.
AppearanceCollection ISCItem
The collection of appearances.
AlphaValue Float Null
Defines the local alpha transparency value between 0 and 1 for the node. The effective alpha value is combined with the materials alpha value of the node.
IsRenderingEnabled Boolean Null, True, False
Defines if node is rendered or not at both, design-time and run-time. If disabled, also descendants are not rendered.
ScopeBits UInt32 Null
Assigns node to scope(s) specified. If specified recursively, this setting is applied to all descendants as well. A scope forms conceptual groups independent of the scene graph hierarchy used e.g. for visibility and light culling. Visibility Culling: Node is rendered only if in same scope of camera. Light culling: Node is illuminated only if in same scope as light.
ScriptComponentCollection ISCItem
NodeObject_ScripComponentCollectionPropertyTooltip
IsTemplate Boolean Null, True, False
If set then the object can be a template for the creation of other objects.
Id UInt32 Null
SymbolicName String
Symbolic names are translated to Ids in Candera, so they must be valid C++ identifiers. C++ identifiers can contain letters, numbers, and underscores. They must start with either a letter or an underscore.
TemplateName String
The path to the imported artifacts that serve as source.
Name String
The name of the object.
KnownTemplateNodes Collection
Collection of templates nodes that are known to the instance. This property is used when comparing the insatnce with its template to decide which nodes are new and which were deleted explicitly.
dyn Collection
Description String
Description of this item.
PreserveSCMLDocumentFormattingScope PreserveSCMLDocumentFormattingScope Null, Global, Local
Indicated the scope for the Preserve SCML Document Formatting property
PreserveSCMLDocumentFormatting Boolean Null, True, False
The formatting of the SCML documents will be preserved only if it is set to true, otherwise the formatting will be reset when the solution is saved
IsLocked Boolean Null, True, False
Indicates if this item is locked.
AnchorDefinition Node String
When expanding the composite node the content of the anchor will be put in this node.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Appearance Material ISCItem
The material.
RenderMode ISCItem
The render mode associated.
ShaderProgramName String
The shader program. Shader programs are configured in Shader panel and can be applied by dragging and dropping on the appearance node.
UniformSetter ISCItem
Uniform setter.
TextureCollection TextureCollection
The collection of textures.
IsEncapsulated Boolean Null, True, False
Indicates if the item is encapsulated.
IsInstanceSharingEnabled Boolean Null, True, False
Indicate if a node attachment should be shared.
SharedInstanceId Int32 Null
Indicate which shared instance of the node attachment to use.
PublicPropertyDefinitions Collection
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
IsShaderProgramSet Boolean True, False
This property is used only if no shader program is set explicitelly on an appearance. If this property is set to true and no shader program is set explicitelly SC will determine which shader program to used based on the default shader mapping. Otherwise no shader will be used.
Billboard Alignment BillboardAlignment Null, CameraUpAlignment, WorldUpAlignment, YawAxisAlignment, FixedAlignment
The alignment of the billboard regarding all cameras which renders the billboard.
Width Float Null
Defines the billboard's total width (the horizontal center of the Billboard is at width/2).
Height Float Null
Defines the billboard's total height (the vertical center of the Billboard is at height/2).
BottomLeft Coordinate
The texture coordinate which corresponds to the bottom left vertex.
TopLeft Coordinate
The texture coordinate which corresponds to the top left vertex.
BottomRight Coordinate
The texture coordinate which corresponds to the bottom right vertex.
TopRight Coordinate
The texture coordinate which corresponds to the top right vertex.
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Defines the render order rank. The node is sorted by rank if assigned to a render order bin having "Criterion" property set to "Render Order Rank" and "Sorting" enabled.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Camera RenderTargetName String
Name of the render target the camera renders to
LookatVector Vector3
Defines the direction vector the camera looks alongside in the local coordinate space.
UpVector Vector3
Defines the local up-vector of this camera in the local coordinate space in order to define the orientation of the camera looking alongside the look-at vector.
Viewport Rectangle
The viewport describes an rectangle area that is updated within the associated render target. The viewport is in normalized coordinates but may exceed that range [0..1] and therefore the render target's boundaries. The viewport distorts the render output if the aspect ratio of the camera does not match the viewports aspect ratio.
IsColorClearEnabled Boolean Null, True, False
Defines if camera shall clear the color buffer with the clear color before it renders.
ClearColor Color
If color clear is enabled, the clear color is applied to color buffer before camera is rendered (background color). The area cleared is defined by the viewport.
IsDepthClearEnabled Boolean Null, True, False
Defines if the camera shall clear the depth buffer before rendering with the clear color defined.
ClearDepth Float Null
If "Clear Depth Buffer" property is enabled, the depth buffer is cleared to the given level before camera is rendered. The area cleared is defined by the viewport.
IsStencilClearEnabled Boolean Null, True, False
Determines whether or not the stencil buffer is cleared after rendering.
StencilClearValue Int32 Null
StencilClearValue
IsScissoringEnabled Boolean Null, True, False
ScissorRectangle Rectangle
The scissor rectangle specifies a rectangular region within the Camera's RenderTarget. The scissor rectangles width and height must be greater than 0. A scissor rectangle that intersects the RenderTarget is allowed. If scissoring is enabled (see IsScissoringIsEnabled) pixels outside of the intersection area of viewport and scissor rectangle are clipped.
SequenceNumber Int32 Null
Defines the position of the camera in the sequence of concurrently rendered cameras. A camera with lower sequence number is rendered before a camera with higher sequence number.
IsViewingFrustumCullingEnabled Boolean Null, True, False
Defines if viewing frustum culling is enabled or not. If enabled, objects outside of the viewing frustum are culled before rendering. This typically increases performance and should only be disabled if all objects are known to be in viewing frustum.
IsSwapEnabled Boolean Null, True, False
Enables or disables a swap of Camera's render target after rendering has been processed.
ProjectionType CameraProjectionType Null, Perspective, Orthographic, Generic
Defines the type of projection used by this camera. Perspective projection: natural projection; objects appear smaller upon increasing distance. Orthographic projection: parallel projection; objects appear the same, regardless of distance. Generic projection: a freely customizable projection matrix.
ZNear Float Null
Defines the distance from the camera to the near clipping plane of the viewing frustum in world space coordinates. Objects that are in front of the near clipping plane are discarded. Objects that intersect the near clipping plane are clipped.
ZFar Float Null
Defines the distance from the camera to the far clipping plane of the viewing frustum in world space coordinates. Objects that are behind the far clipping plane are discarded. Objects that intersect the far clipping plane are clipped.
Fov Float Null
Field of view (FoV) specifies the angle of viewing volume to determine the equal-sided left, right, top and bottom clip planes (comparable to zoom lenses).
Aspect Float Null
The aspect ratio of width to height of the captured scene. If the render output shall not be stretched, the aspect ratio matches the viewport's or render target's aspect ratio
AspectInherited Boolean Null, True, False
Width Float Null
The width of captured area
Height Float Null
The height of captured area.
ProjectionMatrix Matrix4
Generic projection matrix that defines how objects in world space coordinates are projected into homogeneous clip space coordinates.
RenderStrategy CameraRenderStrategy Null, None, Benchmark, OcclusionCulling
The render strategy affects only the processing of that camera and its captured nodes. It is used to determine if rendering shall proceed, pause, or stop for a given node in a Camera's render pass. Occlusion culling render strategy applies only to OpenGLES 3.0 platforms
BenchmarkTreshold Float Null
Sets the threshold for the accumulated Node's render benchmark values. When the sum of the nodes exceeds the threshold this render strategy prompts the class Renderer to pause or stop the camera render pass, according to the render pass action set for threshold.
QueryType QueryType Null, AnySamplesPassed, AnySamplesPassedConservative
Query Type provides a hint to the driver to either use an accurate method (AnySamplesPassed) or a faster approximation (AnySamplesPassedConservative) for determining occlusion
IsRenderingInDisplayDesignEnabled Boolean Null, True, False
Indicates if the rendering is enabled in the Display design
PreviewScissoringScope PropertyValueScope Null, None, Global, Local
PreviewScissoringColor Color
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Composite IsCanvasComposite Boolean Null, True, False
Indicates is the Composit is of type Canvas.
RenderOrderBins Collection
Collection of the render order bins
EditorClearColorScope EditorClearColorScope Null, None, Global, Local
Scene editor clear color scope
EditorClearColor Color
Indicates the background color used with the scene editor camera.
Widgets Collection
Collection of widgets
EditorProfile String
The Editor Profile associated to the scene
Theme String
The theme.
Anchors Collection
Uniform setter.
CompositeProperties Collection
Collection of composite properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositeNode CompositeName String
The name of the composite
CompositeProperties CompositeProperties
The dinamic properties of the node
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositeProperties Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositePropertyDefinition Widget String
Full name of the widget in the composite.
WidgetProperty String
The name of the widget property
SourceItem String
SourceProperty String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
DynamicProperty Name String
Name
Value String
The value of the dynamic property
Type String
The type of the dynamic property
CompositePropertyDefinition String
Name of the composite property definition.
Gizmo IsTemplate Boolean Null, True, False
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Group Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Light LightType LightType Null, Ambient, Directional, Point, Spot
The kind of this light emitting source: Ambient light: illuminates the scene from all directions. The light intensity is the same everywhere in the scene. Position and direction of an ambient light source have no effect. Directional light: corresponds to sunlight in the real world. Illuminates all objects in the scene from the same direction, and with a constant intensity. Position and attenuation of a directional light source have no effect. Point light: casts equal omnidirectional illumination from the position of the light source. The intensity of light coming from a point light source can diminish with distance. The direction of a point light has no effect. Spot light: casts a light cone from a position centered around a direction. A spot light has both a direction and a position. The type of a light source can be changed at any time. This might be useful for switching to a simpler lighting model. Illumination is enabled, if light has rendering enabled and if the node is in the same scope as the light.
Ambient Color
Defines the ambient color component that illuminates the ambient color component of the material.
Diffuse Color
Illuminates the diffuse color component of the material. Ignored if type of light is Ambient.
Specular Color
Defines the specular color component that illuminates the specular color component of the material. Ignored if type of light is Ambient.
Direction Vector3
Defines the direction of the light. Ignored if type of light is Ambient or Point.
Range Float Null
The range from light to geometry in world space where illumination is applied. Ignored if type of light is Ambient or Directional.
ConstantAttenuation Float Null
Defines the constant attenuation factor of the light. The attenuation equation is: 1 / (constant + (linear * distance) + (quadratic * distance^2)). Ignored if type of light is Ambient or Directional.
LinearAttenuation Float Null
Defines the linear attenuation factor of the light. The attenuation equation is: 1 / (constant + (linear * distance) + (quadratic * distance^2)). Ignored if type of light is Ambient or Directional.
QuadraticAttenuation Float Null
Defines the quadratic attenuation factor of the light. The attenuation equation is: 1 / (constant + (linear * distance) + (quadratic * distance^2)). Ignored if type of light is Ambient or Directional.
SpotAngle Float Null
Defines the spot angle of the light cone in degrees. Ignored if type of light is Ambient, Directional, or Point.
SpotExponent Float Null
The distribution of the light within the spot light cone. Ignored if type of light is Ambient, Directional, or Point.
IsAttenuationEnabled Boolean Null, True, False
Enables or disables the attenuation of light. The greater the distance of an object's geometry to the light the less illumination is applied. Ignored if type of light is Ambient or Directional.
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Material Ambient Color
Defines the ambient color of the material illuminated by ambient component of light.
Diffuse Color
Defines the diffuse color of the material that is lit by the diffuse component of light. The diffuse alpha value represents the alpha value of the entire material. Alpha values of other material color components are ignored.
Emissive Color
Defines the emissive color of material, which is a self-illuminating color component not influenced by light. Emissive color does not illuminate other materials in the environment as light does.
Specular Color
Defines the specular color of the material illuminated by the specular component of light.
Power Float Null
Defines the shininess of the material for specular highlights.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Mesh VertexBufferName String
Identifies the vertex buffer which provides model geometry data for this element.
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
PointSprite PointSize Float Null
Defines the size in pixels of this point sprite
PointSizeScaleA Float Null
Defines the point size scale factor A in relation to the cameras distance. The effective size is calculated as follows: pointSize * SquareRoot(1.0 / (A + B*D + C*D*D)) where D is the distance to the camera and A, B, C are the point size scale factors.
PointSizeScaleB Float Null
Defines the point size scale factor B in relation to the cameras distance. The effective size is calculated as follows: pointSize * SquareRoot(1.0 / (A + B*D + C*D*D)) where D is the distance to the camera and A, B, C are the point size scale factors.
PointSizeScaleC Float Null
Defines the point size scale factor C in relation to the cameras distance. The effective size is calculated as follows: pointSize * SquareRoot(1.0 / (A + B*D + C*D*D)) where D is the distance to the camera and A, B, C are the point size scale factors.
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
ReflectionCamera PlaneDirection Vector3
Direction of the vector normal to the mirror plane for the reflection.
PlaneDistance Float Null
Distance of the mirror plane to the camera
UpVector Vector3
Viewport Rectangle
ClearColor Color
StencilClearValue
ZNear Float Null
ZFar Float Null
Fov Float Null
Aspect Float Null
Width Float Null
Height Float Null
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderMode CullMode RenderModeCulling Null, FrontFaceCulling, BackFaceCulling, NoCulling
Set culling mode which determines the side of polygon to remove before rasterization. Typically enabled for opaque objects in order to save processing time.
CullModeInherited Boolean Null, True, False
Flag indicating if the property CullMode is inherited from the DefaultRenderMode configuration.
WindMode RenderModeWinding Null, ClockWise, CounterClockWise
Specifies which face of a polygon is considered a front face for culling
WindModeInherited Boolean Null, True, False
Flag indicating if the property WindMode is inherited from the DefaultRenderMode configuration.
ColorWriteEnabled ColorMask
Enable or disable writing of the incoming fragment's color value into color buffer.
ColorWriteEnabledInherited Boolean Null, True, False
IsDepthWriteEnabled Boolean Null, True, False
Enables or disables writing of the incoming fragment's depth value to depth buffer.
IsDepthWriteEnabledInherited Boolean Null, True, False
Flag idicating if the property DepthWriteEnabled is inherited from the DefaultRenderMode configuration
IsDepthTestEnabled Boolean Null, True, False
Enables or disables the test of the incoming fragement's depth value. If disabled then also the depth write is disabled.
IsDepthTestEnabledInherited Boolean Null, True, False
Flag idicating if the property DepthTestEnabled is inherited from the DefaultRenderMode configuration
DepthComparisonFunction RenderModeComparisonFunction Null, Never, Less, Equal, LessEqual, Greater, NotEqual, GreaterEqual, Always
Defines the depth test comparison function to determine which source depth value passes the depth test. The source pixel is compared to the destination pixel using the given comparison function. Example: If the comparison function is 'Less', then the depth test is passed if the source pixel has a smaller depth value than the destination pixel. In case of comparison function 'Never', the depth test will never pass; in case of 'Always', the test passes always.
DepthComparisonFunctionInherited Boolean Null, True, False
DepthBiasInherited Boolean Null, True, False
Flag indicating if the property DepthBias is inherited from the DefaultRenderMode configuration.
DepthBiasScaleFactor Float Null
Specifies a scale factor that is used to determine how much bias can be applied to primitives.
DepthBiasUnits Float Null
Defines a constant depth offset used to determine how much bias can be applied to primitives.
IsBlendingEnabled Boolean Null, True, False
Enables or disables blending.
IsBlendingEnabledInherited Boolean Null, True, False
Flag indicating if the property IsBlendingEnabled is inherited from the DefaultRenderMode configuration.
BlendColor Color
Defines a constant blending color that can be used in blending equations, if a constant color blend factor is selected.
BlendColorInherited Boolean Null, True, False
Flag indicating if the property BlendColor is inherited from the DefaultRenderMode configuration.
BlendModeInherited Boolean Null, True, False
Flag indicating if the property BlendMode is inherited from the DefaultRenderMode configuration.
SourceBlendFactorRGB RenderModeBlendFactor Null, Zero, One, SourceColor, InverseSourceColor, SourceAlpha, InverseSourceAlpha, DestColor, InverseDestColor, DestAlpha, InverseDestAlpha, ConstantColor, InverseConstantColor, ConstantAlpha, InverseConstantAlpha, SourceAlphaSaturate
Specifies the source RGB fragment coefficient in blending equation
DestBlendFactorRGB RenderModeBlendFactor Null, Zero, One, SourceColor, InverseSourceColor, SourceAlpha, InverseSourceAlpha, DestColor, InverseDestColor, DestAlpha, InverseDestAlpha, ConstantColor, InverseConstantColor, ConstantAlpha, InverseConstantAlpha, SourceAlphaSaturate
Specifies the destination RGB fragment coefficient in blending equation
BlendOperationRGB RenderModeBlendOperation Null, Add, Subtract, ReverseSubtract, Min, Max
Defines operation how RGB values are blended. The blending equation is as follows: ("RGB Source" * "RGB Source Blend Factor") (+"RGB Blend Operation"+) ("RGB Destination" * "RGB Destination Blend Factor").
SourceBlendFactorAlpha RenderModeBlendFactor Null, Zero, One, SourceColor, InverseSourceColor, SourceAlpha, InverseSourceAlpha, DestColor, InverseDestColor, DestAlpha, InverseDestAlpha, ConstantColor, InverseConstantColor, ConstantAlpha, InverseConstantAlpha, SourceAlphaSaturate
Specifies the source alpha fragment coefficient in blending equation
DestBlendFactorAlpha RenderModeBlendFactor Null, Zero, One, SourceColor, InverseSourceColor, SourceAlpha, InverseSourceAlpha, DestColor, InverseDestColor, DestAlpha, InverseDestAlpha, ConstantColor, InverseConstantColor, ConstantAlpha, InverseConstantAlpha, SourceAlphaSaturate
Specifies the destination alpha fragment coefficient in blending equation
BlendOperationAlpha RenderModeBlendOperation Null, Add, Subtract, ReverseSubtract, Min, Max
Defines operation how alpha values are blended. The blending equation is as follows: (SourceAlpha * SourceBlendFactorAlpha) (+BlendOperationAlpha+) (DestAlpha * DestBlendFactorAlpha).
IsStencilTestEnabled Boolean Null, True, False
Enable or disable the stencil test against the stencil buffer.
IsStencilTestEnabledInherited Boolean Null, True, False
Flag indicating if the property IsStencilTestEnabled is inherited from the DefaultRenderMode configuration.
StencilFrontFunctionInherited Boolean Null, True, False
Flag indicating if the property StencilFrontFunction is inherited from the DefaultRenderMode configuration.
StencilFront.ComparisonFunction RenderModeComparisonFunction Null, Never, Less, Equal, LessEqual, Greater, NotEqual, GreaterEqual, Always
A comparison function specifies how the source (new) data is compared against the destination (existing) data before passing the comparison operations (storing the data).
StencilFront.Value Int32 Null
Set stencil function and reference value for stencil testing.
StencilFront.Mask UInt32 Null
Set the write mask applied to values written into the stencil buffer.
StencilFrontOperationInherited Boolean Null, True, False
Flag indicating if the property StencilFrontOperation is inherited from the DefaultRenderMode configuration.
StencilFront.StencilFail StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
Set stencil operations applied to the stencil buffer for the next condition: The fragment fails the stencil test. (Subsequent depth test and other tests will not be applied.)
StencilFront.DepthFail StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
Set stencil operations applied to the stencil buffer for the next condition: The fragment fails the depth test after the stencil test passed.
StencilFront.DepthPass StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
Set stencil operations applied to the stencil buffer for the next condition: The fragment passes both the stencil and depth test.
StencilFront.WriteMask UInt32 Null
Write mask applied to values written into the stencil buffer.
StencilFrontWriteMaskInherited Boolean Null, True, False
Flag indicating if the property StencilFrontWriteMask is inherited from the DefaultRenderMode configuration.
StencilBackFunctionInherited Boolean Null, True, False
Flag indicating if the property StencilBackFunction is inherited from the DefaultRenderMode configuration.
StencilBack.ComparisonFunction RenderModeComparisonFunction Null, Never, Less, Equal, LessEqual, Greater, NotEqual, GreaterEqual, Always
StencilBack.Value Int32 Null
StencilBack.Mask UInt32 Null
StencilBackOperationInherited Boolean Null, True, False
Flag indicating if the property StencilBackOperation is inherited from the DefaultRenderMode configuration.
StencilBack.StencilFail StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
StencilBack.DepthFail StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
StencilBack.DepthPass StencilOperation Null, SetToZero, Keep, Replace, Increment, Decrement, Invert, IncrementWrap, DecrementWrap
StencilBack.WriteMask UInt32 Null
StencilBackWriteMaskInherited Boolean Null, True, False
Flag indicating if the property StencilBackWriteMask is inherited from the DefaultRenderMode configuration.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderOrderBin IsPredefined Boolean Null, True, False
Protected render order bin are maintained by Candera and cannot be deleted or removed.
IsSortingEnabled Boolean Null, True, False
Enables or disables the sorting of this bin according to the order criterion set.
Criterion RenderOrderCriterion Null, DistanceToCamera, ReverseDistanceToCamera, RenderOrderRank, ReverseRenderOrderRank, BatchOrder
The order criterion specifies according to which sorting criteria the nodes in a render order bin are sorted.
BatchOrder BatchOrderCriterion Null, SortByShaderAndRenderMode, SortByAppearance
The batch order criterion specifies according to which sorting criteria the nodes in a render order bin are sorted.
DistanceFunction RenderOrderDistanceFunction Null, CameraPositionToBoundingSphere, CameraPositionToBoundingBox, ViewPlaneToBoundingSphere, ViewPlaneToBoundingBox
Determines how the distance from camera to any node is calculated.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderTarget Display String
The display of the render target
PreviewBorderScope PropertyValueScope Null, None, Global, Local
Configures the preview border for this object. It can be used from the global preferences.
PreviewBorderColor Color
Configures the preview border color for this object.It can be used from the global preferences.
Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Scene RenderOrderBins Collection
Widgets Collection
Theme String
The theme.
Anchors Collection
Collection of anchors
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
StereoCamera EyeSeparation Float Null
Eye Separation
ConvergenceDistance Float Null
Convergence Distance
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Texture TextureType TextureType Null, SingleMap, CubeMap
Texture type.
ImageName String
Identifies the bitmap or texture render target which provides pixel data for this texture.
BitmapName String
Identifies the bitmap which provides pixel data for this texture.
TextureRenderTargetName String
Identifies the texture render target which provides pixel data for this texture.
PositiveXImageName String
The image associated to the PositiveX face of this cube map texture.
NegativeXImageName String
The image associated to the NegativeX face of this cube map texture.
PositiveYImageName String
The image associated to the PositiveY face of this cube map texture.
NegativeYImageName String
The image associated to the NegativeY face of this cube map texture.
PositiveZImageName String
The image associated to the PositiveZ face of this cube map texture.
NegativeZImageName String
The image associated to the NegativeZ face of this cube map texture.
Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
MagnificationFilter TextureMinMagFilter Null, Nearest, Linear
Filter used for up-scaling texture (texture is bigger than image source). Linear filter provides higher quality be less performance.
MinificationFilter TextureMinMagFilter Null, Nearest, Linear
Filter used for down-scaling texture (texture is smaller than image source). Linear filter provides higher quality be less performance.
MipMapFilter TextureMipMapFilter Null, MipMapNone, MipMapNearest, MipMapLinear
Filter used for applying mipmaps. Linear filter provides higher quality be less performance.
WrapModeU TextureWrapMode Null, Repeat, ClampToEdge, MirroredRepeat
Sets wrap mode for texture coordinate U (x-dimension). Repeat: If texture coordinate is less zero or greater 1 the texture is repeated. MirroredRepeat: If texture coordinate is less zero or greater 1 the texture is repeated mirrored contiguously. ClampToEdge: If texture coordinate is less zero or greater 1 the textures adjacent border pixel is drawn. In order to support repeated wrapping, the bitmap's width and height must be a power of 2 (n^2), like e.g. 2, 4, 8, 16 ,32, etc. Width and height can be different, e.g.: 256x128.
WrapModeV TextureWrapMode Null, Repeat, ClampToEdge, MirroredRepeat
Sets wrap mode for texture coordinate V (y-dimension). Repeat: If texture coordinate is less zero or greater 1 the texture is repeated. MirroredRepeat: If texture coordinate is less zero or greater 1 the texture is repeated mirrored contiguously. ClampToEdge: If texture coordinate is less zero or greater 1 the textures adjacent border pixel is drawn. In order to support repeated wrapping, the bitmap's width and height must be a power of 2 (n^2), like e.g. 2, 4, 8, 16 ,32, etc. Width and height can be different, e.g.: 256x128.
Anisotropy Float Null
Set the maximum degree of anisotropy. Anisotropic texture filtering is a view-dependent, adaptive filter technique to increase texture quality. The higher the degree of anisotropy, the higher the quality.
IsFalseColorEnabled Boolean Null, True, False
If checked, mipmap-levels are visualized by colors, otherwise attached textures are rendered.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Theme IsTemplate Boolean Null, True, False
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
ThemeEntry Interface String
Full name of the theme entry interface implemented by this this entry.
EntryItem String
The item in the solution which will be used by all clients of this entry. If entry item is null, the master theme will be used. The master theme can not contain any empty entries.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Widget WidgetNodeName String
The name of the node associated to the widget
Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
