Locking/Unlocking the Properties Panel
Some behaviors like e.g. the ForwardValue behavior have a property TargetNode. The appropriate TargetNode can be assigned by pressing the respective icon button, which will open the "Choose Item" dialog as shown in a Behavior example.
There is an alternative - possibly more comfortable - way to configure the TargetNode via drag & drop.
Like various DCC tools and Game Engines,Development Platforms, Scene Composer employs a locking and unlocking method for the Properties panel to significantly enhance the workflow efficiency for designers.
This method the user to lock the properties panel on the top right side of the property panel and move SCItems via drag and drop into the property fields. The value that is being copied into the fields is the path (if the field requires it) or the name of the item.
How to use the Locking/Unlocking method
- Select the object to display the TargetNode to be configured in the properties panel.
- In the Properties panel: Click the lock button in the top right corner to lock the panel. (As long as this panel is locked, it will display the properties of the object that was selected at the time it was locked.)
- In the Scene Tree panel: Navigate to the node that you want to configure as TargetNode.
- Drag this node from the Scene Tree panel and drop it onto the TargetNode property.
- In the Properties panel: Click the lock button again to unlock the panel.
Limitation: Drag&drop doesn't work for external (windows) files.
