2D Scene Editor
See Also : 2D Editing Helpers
General
By default, only one Scene Editor is displayed (Scene Editor (0)-0 only). You can display up to four Scene Editors (Scene Editor (0)-0 to (-4)) as needed. You can show or hide them from the menu bar [ View > Editors > Scene Editor ].
    Scene Editor menu on the Menu Bar
    The [ Display Scene Editor ] icon on the toolbar
    When you click the [ Display Scene Editor ] icon, four icons will appear for toggling the visibility of the Scene Editor. Please refer to the table below for details on each icon.
    The Scene Editor -0 is displayed.
    The Scene Editors -0 and -1 are displayed.
    Scene Editors -0 through -2 are displayed.
    Scene Editors -0 through -3 are displayed. When a display setting not listed in the table above is applied in the Scene Editor menu on the Menu Bar, the [ Display Scene Editor ] icon will display "Custom".
    Additionally, scene editors (1) to (3) support floating display. By using floating display, you can display any scene editor on a separate display.
    If the displayed Scene (or Control) is updated, it will be reflected in all Scene Editors.
    Camera Manipulation
    • Editor camera: A default camera named "Editor", which can be used to edit the scene including all scene cameras from an outer perspective.
    • Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree panel.
    Camera Panning and Zooming
    • Panning: Move the mouse while holding the middle mouse button down;
      or move the mouse while holding the <CTRL> and <SHIFT> keys and the left mouse button
    Fit to Screen
    To display the entire content of your 2D scene or 2D Control in the Scene Editor window, click the "Fit to Screen" button. All objects  of the scene or control will become visible - even those outside the yellow viewport rectangle.
    Reset Camera
    Camera Preview Thumbnail
    • 512x512px for 2D cameras
    • on a surface of the same dimensions and then reduced to a thumbnail image - for 2D cameras
    Select
    Translate
    • "Pivot and Object" will move the selected object with its pivot
    • "Pivot only" will move only the pivot of the selected object.
    Scale
    • the object itself
    • X axis controller - when dragging the axis, the object will be scaled on the local x axis
    • Y axis controller - when dragging the axis, the object will be scaled on the local y axis
    • Lock scaling controller - displayed on the lower right corner of the render node. When dragging it, the object will be scaled proportional on each axis.
    Rotate
    Unselect an Item
