2D Scene Editor
TwoThis page describes the two types of interactions that are possible with the render view:view.
See Also : 2D Editing Helpers
Camera Manipulation
  • Editor camera: A default camera named "Editor", which can be used to edit the scene including all scene cameras from an outer perspective.
  • Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree panel.
Camera Panning and Zooming
Fit to Screen
To display the entire content of your 2D scene or 2D Control in the Scene Editor window, click the "Fit to Screen" button. All objects  of the scene or control will become visible - even those outside the yellow viewport rectangle.
Reset Camera
Camera Preview Thumbnail
  • 512x512px for 2D cameras
  • on a surface of the same dimensions and then reduced to a thumbnail image - for 2D cameras
Select
Translate
  • "Pivot and Object" will move the selected object with its pivot
  • "Pivot only" will move only the pivot of the selected object.
Rotate
Scale
  • the object itself
  • X axis controller - when dragging the axis, the object will be scaled on the local x axis
  • Y axis controller - when dragging the axis, the object will be scaled on the local y axis
  • Lock scaling controller - displayed on the lower right corner of the render node. When dragging it, the object will be scaled proportional on each axis.
Unselect an Item
