2D Scene Editor
Two types of interactions are possible with the render view:
See Also : 2D Editing Helpers
Camera Manipulation
- Editor camera: A default camera named "Editor", which can be used to edit the scene including all scene cameras from an outer perspective.
- Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree panel.
Camera Panning and Zooming
- Panning: Move the mouse while holding the middle mouse button down
- Zooming: Rotate the mouse wheel forward for zooming in and backward for zooming out
It is possible to zoom any 2D scene oriented toward a point indicated by the cursor (similar with Google Earth zoom). By placing the cursor on any point in a 2D scene, when zooming operation is doing the whole scene toward that selected point.
Camera Preview Thumbnail
- 512x512px for 2D cameras
Reset Camera
Select
Translate
- "Pivot and Object" will move the selected object with its pivot
- "Pivot only" will move only the pivot of the selected object.
Rotate
Scale
- the object itself
Unselect an Item
