Post Processing Solution
This sample demonstrates how to implement and control post-processing effects in Scene Composer using scripts. It enables toggling effects on and off at runtime and allows property adjustments through UI controls like toggle buttons and sliders.
Purpose
The goal of this sample is to showcase the simplicity and flexibility of applying post-processing effects via scripts. It provides a practical example of how to enable/disable multiple effects at runtime and animate their properties interactively using UI elements.
Key elements of this sample include the cameras in Scene3D_FX (both the main and reflection cameras) and in Scene2D_FX (UI camera). These cameras have post-processing scripts attached, taken from the Construction Kit as Script Components.
The scripting system for the Player can be enabled via the State Machine using the Enable Scripting System behavior or toggled on/off through the CGI Player Panel using the Toggle Scripting System option.
The Scene2D_UI handles switching between 2D and 3D views and provides toggle buttons for enabling/disabling individual post-processing effects. Each camera has a script (e.g., Camera.lua for 3D and Camera2D.lua for 2D) that stores its ID in a global table. Group nodes named after effects (e.g., BloomDummy, FXAADummy) have attached scripts (EnableCameraScript.lua, 2DEnableCameraScript.lua) that control the activation of those effects. Post-processing scripts are toggled by enabling or disabling the rendering of these dummy nodes using the Enable Rendering Action behavior.
Several post-processing properties are animated and can be modified at runtime using sliders in the UI. Additionally, there's a Material Control section where users can adjust the PBR shader properties of the 3D model—such as Base Color (R, G, B), Glossiness, and the intensity of the Baked Ambient Occlusion texture—using the same slider mechanism.
For a deeper understanding of the script functionalities, refer to the comments within each script file.
Example of post-processing a 2D scene
Example of post-processing a 3D scene
The script system of the Player can be started by typing "start script" into the Player's command window or by enabling Player > Scripting System in the CGI Panel's menu bar.
To stop the script system type "stop script" or by enabling Player > Scripting System in the CGI Panel's menu bar or by disabling Player > Scripting System in the CGI Panel's menu bar.
