Post Processing Solution
This sample demonstrates how to implement and control post-processing effects in Scene Composer using scripts. It enables toggling effects on and off at runtime and allows property adjustments through UI controls like toggle buttons and sliders.
Purpose
The post-processing feature is simple to use and can be easily applied with scripts. This sample shows how to use and combine them in Scene Composer and en-/disable them at runtime.
The most important nodes of the sample are cameras in the 3D and 2DFX scenes. These cameras have post-processing scripts attached. They are taken from the Construction Kit as Script Components. When the sample is started in the Player, the scripting system for the Player has to be enabled. Then, the buttons of the 2D scene allow to switch between 3D and 2D scenes and to enable or disable each effect. To approach this behavior, additional scripts have been added to the solution. In general it works in the way that the camera has a further script attached that stores its ID in a global table. Other scripts (attached to other nodes) access this table to be able to enable the post-processing scripts. The cubes also have scripts attached, that control the rotation of the cubes and their color or opacity. For a more detailed description of what the scripts do please refer to the comments in the scripts themselves.
Example of post-processing a 2D scene
Example of post-processing a 3D scene
The script system of the Player can be started by typing "start script" into the Player's command window or by enabling Player > Scripting System in the CGI Panel's menu bar.
To stop the script system type "stop script" or by enabling Player > Scripting System in the CGI Panel's menu bar or by disabling Player > Scripting System in the CGI Panel's menu bar.
