Pollen Infoscreen
Run Pollen Infoscreen Sample
To run the solution with the player connector in simulation environment the following steps have to be executed:
- Generate the simulation asset of the Pollen Infoscreen Sample Solution and save it in
<cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\PollenInfoScreen - Obtain the API Key from Polleninformation Datenschnittstelle / API | Polleninformation.
Use the contact form to request an API Key. -
After receiving your API key, replace "PUT_YOUR_APIKEY_HERE" with your API key
it can be set inon line 276 of the script
<cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\PollenInfoScreen\PollenInfoScreen.py, as seen below.
If the API Key is not set, you are still able to run the solution, but the information will not be updated.
- Execute the python script
Example usage:
Parameters:python PollenInfoScreen.py ^ -lbp ..\..\..\RaspberryPi_Simulation\PlayerConnector\PlayerConnectorLibrary.dll ^ -abp PollenInfoScreen.bin- -lbp (Library Binary Path)
Path to the PlayerConnector library<cgi-studio-installation-path>\bin\CommunityEdition\RaspberryPi_Simulation\PlayerConnector\PlayerConnectorLibrary.dll - -abp: (Asset Binary Path)
Path to the asset saved previously
To run it on the Target please follow the steps from Run Sample with Player Connector Library.
Overview scene:
Dynamic Elements:
- Clock control
- Air Quality – text value
- DayRisk control (4 week days)
- Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
Insights scene
- ContaminantName control
- 4 x ContaminantLevel
Controls
DayRisk
The risk value has a single entry point and is forwarded to the three controls that each need it. This could also have been done with using fewer elements and arithmetic operator behavior. This is a bit more flexible as it allows to easily add new images for each value, if needed.
PollenBrief
MultihourValue
ContaminantLevel
ContaminantName
ContaminantsListElement
Contaminant
Country
Contaminants_List
GroupBox_List
Scenes
Overview Scene
Insights Scene
This scene only contains a list of the contaminants we know of and their level. It is only meant to be viewed, there are no buttons for interaction. The elements of the list are ContaminantListItem templates. The list has a fixed number of 8 elements. The number of received contaminants can be higher or smaller. If Higher, we only show the first 8. If lower, we disable rendering for the unused elements via a “Render Child Nodes” behavior. When there are more elements than visible in the given space, a scroll-bar will appear (and scale as well as move itself appropriately). To customize the “Scrollbar” with imported graphical elements, the Contaminants_List template is used.
TopBar Scene
BottomBar Scene
In the bottom bar we have buttons to switch between the 2 main scenes. When the button is clicked, the state machine transition occurs. To select between the gray and green versions, a RenderChildNodes behavior is used.
ContaminantList_Popup Scene
Location_popup Scene
This is the largest scene in the solution. There are 2 lists visible, a countries list and a cities list. In the scene there is a list of cities for each country. The Lists of cities are under a node with a “Render Child Nodes” behavior, so only one of the lists of cities is made visible. The index of the list to show is set from the “Country” template of the first list. Like the Contaminants List Popup, this scene has a node to prevent events going to the elements under it, and a full screen button to exit when tapping outside.
Other elements
Below you can find more information on the remaining elements not beloning in the controls and scenes chapter.
Associated script (WebAPI)
This app is based on the Web API and data from www.polleninformation.at. The API is not public, but a free api key can be obtained for various usecases. More info is available at:At https://www.polleninformation.at/datenschnittstelle. you can find information about the format of the URL used to retrieve the data, and the format of the response JSON. Here you can also see the data needed for API requests, and the data received. In short, to make a request we need language, country, and geographic coordinates, which we can get from databinding, from strings preset in the asset.
The python script can be found in cgi_studio_player/src/PlayerConnector/Python/Samples/PollenInfoScreen, and your API key can be set in line 276 of the script, as seen below.
State Machine
Animations
