Pollen Infoscreen
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality – text value
  • DayRisk control (top 4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 34 levels, triggers list of contaminants)
  • City Button (triggers location list)
Settings Button (triggers language list) Insights Button (switches to contaminants list scene)
Insights scene:
ContaminantListElement control – List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk
We have a background, over which there is a string showing the day, an icon according to risk level, a number representing risk values from 0 to 10, and a second fixed text or icon for risk level. The risk level has only 34 values,values: none, low, mid, high.
The Control only needs to receive the day text, and the risk level. For the Icons and risk level text, we can use a “Render Child Nodes” behavior to select which element to make visible, and we can setup with 1011 elements, by duplicating the 34 available elements (none, low, med, high) to (none, low, low, low, med, med, med, med, high, high, high).
PollenBrief
MultihourValue
ContaminantLevel
ContaminantsLevel_IconsBehaviors.png                 ContaminantLevel_Structure&Behaviors.png
ContaminantName
ContaminantsListElement
As mentioned, some buttons trigger lists, which have similar designs: language list, very similar to contaminants list,list and locations list. These are meant to allow selection of a list element, which will remain highlighted.
Contaminant
This template was designed for elements of the contaminants list, but could then be reused for the language selection list, since it has the same functionality.list. The template consists of a “Radio Button”, to allow for a single element to be selected, and a “Text” control. The normal RadioButton text was set to an empty string, and the actual text is set in the “Text” control, to allow more configuration options for it’s properties (font, size, color). The white/red background images are set in the “Radio Button” control properties.
The Radio button has a “Value” behavior, which will become true when selected, and false when deselected. Under this value we have 2 “Action On Value” behaviors, one to trigger actions when becoming selected, and one to trigger actions when becoming unselected.
The public properties give expose only what we need to configure from the outside. This can be reused for languages, by setting the language code as ScientificNameString, and the normal language string as NormalNameString.
Country
The country list button template is similar to the Contaminant/Language one, but instead of sending out 2 strings, it send one string with country code, andsends an integer to be used as index, to select which list of cities to be shown to the right of the current country.country,
and also a boolean false value to reset the selection in the list of associated cities. This way there will be no city selected for a country until user selects one, and the last city selected by user will be used, regardless of the state of the list, or which country is currently selected.
City
The city button template is similar to the Country template, but instead of sending an index, it has to send the city name, the country code, and the longitude and latitude of the city. These could naturally be represented as floating point numbers, but they will be needed as strings when creating a web request anyway, so we can set them to string type.
 The country code is sent from here and not the country list, to keep them consistent, in case the country is changed and no new city is selected.
The app has 2 main scenes, the “Overview” and the “Insights” scene, and can switch between them using the buttons on the bottom bar. The “TopBar” and “BottomBar” scenes are always loaded and visible. For selecting items from lists, there are also some smaller scenes always loaded, and their visibility is controlled by triggering animations: “Location_Popup”, “ContaminantsList_Popup” and “Language_Popup”.
Contaminants_List
GroupBox_List
Scenes
State Machine
Overview Scene
This scene is the most complex of the solution, but it can be managed easily by using several of the templates previously described.
TopLeft: Here we just have a number from 10 to 10, showing the allergy risk for today, and some static text around it. A default “Text Value” control is used, and configured with font style, color, format and data binding.
TopRight: Here we have a list of allergy risk values for today and the next 3 days. Beside the value and day of the week, each also has an icon and fixed text for none, low, moderate, or high risk. For this we use the DayRisk template, and a StackLayout to allign them automatically.
Bottom Left: This displays the allergy risk values during the current day, at 4 hour intervals. The web api provides hourly values, and we display 6 of them, using images associated for value, via the MultihourValue template. The elements are also allligned automatically using a StackLayout.
Bottom Right: Here the user can select a set of 4 contaminants and see the risk level associated with each of them. There are only 34 levels,levels: none, low, mid, high, and no numeric value. We use the PollenBrief template and place them manually. Each element has an associated button, which opens a list from which a user can select a contaminant for the respective slot.
Insights Scene
This scene only contains a list of the contaminants we know of and their level. It is only meant to be viewed, there are no buttons for interaction. The elements of the list are ContaminantListItem templates. The list has a fixed number of 8 elements. The number of received contaminants can be higher or smaller. If Higher, we only show the first 8. If lower, we disable rendering for the unused elements via a “Render Child Nodes” behavior. When there are more elements than visible in the given space, a scroll-bar will appear (and scale move itself appropriately). To customize the “Scrollbar” with imported graphical elements, the “List”Contaminants_List controltemplate wasis expanded here, then configured.used.
TopBar Scene
BottomBar Scene
In the bottom bar we have buttons to switch between the 2 main scenes. We can also add a “Settings” button, it is currently disabled. When the button is clicked, the state machine transition occurs.
 To select between the gray and green versions, a RenderChildNodes behavior is used, and the related value is set by pressing, and databound, to allow the app to know which scene is currently active.
ContaminantList_Popup Scene
This scene is very similar to the Language_Popup, but multipliedcontains 4 times,lists, one list for each of the front page contaminants. We could have had a single list and configure it with the currently selected one upon opening, but this way each will be opened in the same state in which it was closed. String values are sent from the Contaminant template to nodes with databound values, as before, so new contaminants can also be added without the need to modify and recompile the code.
 Rendering is disabled for these 2 nodes, but could be enabled for debug purposes.
Location_popup Scene
This is the largest scene in the solution. There are 2 lists visible, a countries list and a cities list. In the scene there is a list of cities for each country. The Lists of cities are under a node with a “Render Child Nodes” behavior, so only one of the lists of cities is made visible. The index of the list to show is set from the “Country” template of the first list.  Like the Contaminants List Popup, this scene has a node prevent events going to the elements under it, and a full screen button to exit when tapping outside.
This setup makes it possible to add new countries and cities just by configuring the asset. For a country, we need the name, the 2-letternode code,to which it must be forwarded, the index of it’s cities list in the group of city lists, and the nodesroot of the cities list, to whichreset totheir forward the index and the string.selection.
For a city, we need the name to be shown, but more importantly, we need to get it’s geographical coordinates inand country code to the code.app. So we send a LatitudeLatitude, Longitude, and Longitudecountry code to nodes with databindings. Having this in the asset allows to edit, remove, or add any new city to the list just by editing in SceneComposer. The source code will remain unchanged, it will just use the new values received throughtrough databindings.
Animations
Associated script
