Pollen Infoscreen
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality – text value
  • DayRisk control (top 4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 3 levels, triggers list of contaminants)
  • City Button (triggers location list)
  • Settings Button (triggers language list)
  • Insights Button (switches to contaminants list scene)
Insights scene:
ContaminantListElement control – List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk
We have a background, over which there is a string showing the day, an icon according to risk level, a number representing risk values from 0 to 10, and a second fixed text or icon for risk level. The risk level has only 3 values, low, mid, high.
The Control only needs to receive the day text, and the risk level. For the Icons and risk level text, we can use a “Render Child Nodes” behavior to select which element to make visible, and we can setup with 10 elements, by duplicating the 3 available elements (low, med, high) to (low, low, low, med, med, med, med, high, high, high).
PollenBrief
MultihourValue
ContaminantLevel
The contaminant level in the insights list is similar to the DayRisk, but slightly different visuals, and no number displayed (the level is shown by color/icon and text, and we only have low, mid, high).
ContaminantsLevel_IconsBehaviors.png                 ContaminantLevel_Structure&Behaviors.png
ContaminantName
ContaminantsListElement
As mentioned, some buttons trigger lists, which have similar designs: language list, very similar to contaminants list, and locations list. These are meant to allow selection of a list element, which will remain highlighted.
Contaminant
This template was designed for elements of the contaminants list, but could then be reused for the language selection list, since it has the same functionality. The template consists of a “Radio Button”, to allow for a single element to be selected, and a “Text” control. The normal RadioButton text was set to an empty string, and the actual text is set in the “Text” control, to allow more configuration options for it’s properties (font, size, color). The white/red background images are set in the “Radio Button” control properties.
The Radio button has a “Value” behavior, which will become true when selected, and false when deselected. Under this value we have 2 “Action On Value” behaviors, one to trigger actions when becoming selected, and one to trigger actions when becoming unselected.
The public properties give expose only what we need to configure from the outside. This can be reused for languages, by setting the language code as ScientificNameString, and the normal language string as NormalNameString.
Country
The country list button template is similar to the Contaminant/Language one, but instead of sending out 2 strings, it send one string with country code, and an integer to be used as index, to select which list of cities to be shown to the right of the current country.
City
The city button template is similar to the Country template, but instead of sending an index, it has to send the longitude and latitude of the city. These could naturally be represented as floating point numbers, but they will be needed as strings when creating a web request anyway, so we can set them to string type.
The app has 2 main scenes, the “Overview” and the “Insights” scene, and can switch between them using the buttons on the bottom bar. The “TopBar” and “BottomBar” scenes are always loaded and visible. For selecting items from lists, there are also some smaller scenes always loaded, and their visibility is controlled by triggering animations: “Location_Popup”, “ContaminantsList_Popup” and “Language_Popup”.
State Machine
Overview Scene
This scene is the most complex of the solution, but it can be managed easily by using several of the templates previously described.
TopLeft: Here we just have a number from 1 to 10, showing the allergy risk for today, and some static text around it. A default “Text Value” control is used, and configured with font style, color, format and data binding.
