Pollen Infoscreen
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality – text value
  • DayRisk control (top 4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 3 levels, triggers list of contaminants)
  • City Button (triggers location list)
  • Settings Button (triggers language list)
  • Insights Button (switches to contaminants list scene)
Insights scene:
ContaminantListElement control – List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk:
We have a background, over which there is a string showing the day, an icon according to risk level, a number representing risk values from 0 to 10, and a second fixed text or icon for risk level. The risk level has only 3 values, low, mid, high.
The Control only needs to receive the day text, and the risk level. For the Icons and risk level text, we can use a “Render Child Nodes” behavior to select which element to make visible, and we can setup with 10 elements, by duplicating the 3 available elements (low, med, high) to (low, low, low, med, med, med, med, high, high, high).
