Instrument Cluster
Instrument Cluster
Solution Interactions
    For transition between different tiles, Up and Down arrow key inputs and animations were used to shift from one tile to another. Plus and Minus key inputs were used to set ACC distance in ADAS 2D scene Add and Subtract key inputs were used to set ACC speed in ADAS 2D scene Left and Right key inputs were used to handle main car positions.
    Scene
    No. Category Scene Name Description
    (1) ADAS 3D_ADAS_DemoScene 3D scene handles several objects visible on the street (such as bikes, pedestrians, trucks, cars and so on). All the objects are handled with a single ObjectControl feature. ADAS (Advanced Driver Assistance System) features were also included. For more details on ADAS features, please refer to 3D ADAS Control Solution.
    (2) ADAS AdasScene2D
    2D ADAS scene links with 3D scene. For instance, if ACC set distance toggle button is enabled, then distance between car and next object on the road must be visible which can be set based on "plus" and "minus" key inputs. In a similar way, all others like LDD, Side assist, ACC indicators and so on were connected to the 3D ADAS demo scene.
    (3) Background BackgroundScene2D
    (4) Main ClusterHomeScene2D This scene has mainly cluster (circular slider based) to handle speed, power, charge and range. On increase of speed, power increases and charge (regeneration in this case) doesn't reflect the change. As and when speed starts to decrease, power drops to zero and regeneration increases. Range indicates battery of the car which reduces gradually.
    Another part of this scene is the car and adas telltales' control which are connected to 3D ADAS DemoScene.
    (5) Tile MusicScene2D
    Slider control indicates progress bar of song and on next or previous button, song information changes. At the end of every song, it automatically shifts to the next song in the list.
    (6) Tile NavigationScene2D The navigation scene/tile is a placeholder for a navigation solution integration, as there is no "standard" for navigation integrations and strong depend on the navigation software provider solution.
    (7) Tile PhoneScene2D
    All contacts are listed under the scene. On click of any contact, shifts to outgoing call scene where the user has the option to decline call and go back to contacts list.
