Properties Panel - Favorites
Properties Panel
You can save any property as a favorite property. This feature can be enabled by checking the "Enable favorites" checkbox from the section "Environment - Properties" panel, in the "Preferences" dialog.
Add Properties to Favorites
Any property can be saved as a favorite property just by right-clicking on it, after the favorites are enabled.
A "Favorites" category will appear in the Properties, where you can see all the selected favorite properties. Use "Export favorites..." in the "Environment - Property" section for saving all the selected favorite properties on a chosen location (as an .XML document). Any exported .XML favorites document could be imported by using the "Import favorites..." button from the "Environment - Properties panel" section.
Remove Properties from Favorites
The "Reset favorites" button in the "Environment - Properties" panel section allows to reset all the available favorite properties. Right click on a property in the "Favorites" category and select "Remove from Favorites" in the context menu to remove a single one.
