Rendering Only Updated Content
This chapter briefly describes how to achieve performance optimization by rendering only updated content.
Contens List
Introduction
Invalidation Introduction
Basic principles for composing graphical content:
    Place content which is never changed in an own scene and render it to an own layer. Partition content which is frequently changed by widgets or animations. Use several cameras for this purpose. If rarely modified graphical content is part of a dynamic scenery then think about using Texture Render Targets.
    How is it done?
    In the render loop of the application all Widgets are updated by calling Candera::WidgetBase::Update(). The basic render loop looks like this:
      // 3D Render Loop
        // handle input events
        // update animations by calling AnimationDispatcher::DispatchTime()
        if (m_animationDispatcher3D != 0) {
          m_animationDispatcher3D->SetWorldTimeMs(nowMs);
          m_animationDispatcher3D->DispatchTime();
        // update all widgets
        CgiApp::GetInstance().Update();
        Renderer::RenderAllCameras();
      // end 3D Render Loop
    The widgets must now implement a mechanism to tell the application whether associated graphical content needs to be rendered. The following pages explain two ways to achieve this:
    Use SetRenderingEnabled()
    Use Candera::Camera::SetRenderingEnabled() / Candera::Camera2D::SetRenderingEnabled()
    The example below shows how in CGIApplication all 3D cameras are turned off in first step of render loop.
    void CgiApp3dGc::Update() {
        Base::Update();
      // Turn off all cameras
        UInt32 cameraCount = Renderer::GetCameraCount();
        for (UInt32 i = 0; i < cameraCount; i++)
            Camera* cam = Renderer::GetCamera(i);
            cam->SetRenderingEnabled(false);
        // Update widgets in all visible scenes
        WidgetBase* widget = 0;
        Vector<SceneContext*>::ConstIterator it = m_sceneContexts.ConstBegin();
        for (; it != m_sceneContexts.ConstEnd(); it++) {
            if ((*it) != 0 && (*it)->GetScene() != 0 && (*it)->GetScene()->IsRenderingEnabled()) {
                widget = (*it)->GetFirstWidget();
                while (widget != 0) {
                    widget->Update();
                    widget = (*it)->GetNextWidget();
    The Candera::Widget::Update() method needs to be implemented such that the recently turned off camera is turned on again whenever rendering is required. The Candera::Camera can be either set as a widget property or retrieved inside the scene by masking the widget and the associated camera with the same Candera::ScopeMask value.
    void SampleBaseWidget3D::InvalidateCamera(bool value)
      m_camera->SetRenderingEnabled(true);
    void MyWidget::Update()
      // update graphical content from cached property value(s)
      Base::InvalidateCamera(true);
    Pick Camera to Render
    Explicitely Pick Camera to Render
    Another method is to maintain a list of cameras by the application.
    The render loop has to be changed
      to call Candera::Renderer::RenderCamera( Camera * camera ) instead of Candera::Renderer::RenderAllCameras().
      The application needs to take care on Render Buffer Swapping.
