Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
  1. Create a new solution
  2. Opne an existing solution
  3. Save solution...
  4. Open asset library generator dialog...
  5. Open safety asset library generator dialog...
  6. Run/Stop Player/Embedded Player, Update Embedded Player
  7. Select Player/Embedded Player setting (6. Select the player to launch when clicked.)
  8. Player/Embedded Player Selection
  9. Open automation scripts dialog...
  10. Undo
  11. Redo
  12. Add a new 2D scene
  13. Add a new 3D scene
  14. Add a new safety scene
  15. Select active scene
  16. Select perspective (Scene Design/Animation Design/User created perspective)
  17. Display/Hide Scene Editor
  18. Open Culture solution option dialog
  19. Select culture
  20. Create new animation
  21. Select animation
  22. Start animation
  23. Stop animation
  24. Animation fast forward speed
  25. Animation fast forward
  26. Go back to one previous active item
  27. Go forward to one previous active item
  28. Edit current profile
  29. Add a new profile
  30. Delete current profile
  31. Select profile
  32. Start the execution of the script system
  33. Stop the execution of the script system
Icons through 20 to 33 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Animation: 20 to 25, Navigation: 26 and27, Editor Profiles: 28 to 31, Scripting System: 32 and 33)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
