Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
  1. Create a new solution
  2. Opne an existing solution
  3. Save solution...
  4. Open asset library generator dialog...
  5. Open safety asset library generator dialog...
  6. Run/Stop Player/Embedded Player, Update Embedded Player
  7. Select Player/Embedded Player setting
Player/Embedded Player Selection Open automation scripts dialog... Undo Redo Add a new 2D scene Add a new 3D scene
Add a new safety scene Select active scene Select perspective (Scene Design/Animation Design/User created perspective)
Display/Hide Scene Editor Open Culture solution option dialog Select culture Create new animation Select animation Start animation Stop animation Animation fast forward speed Animation fast forward Go back to one previous active item Go forward to one previous active item Edit current profile Add a new profile Delete current profile Select profile Start the execution of the script system Stop the execution of the script system
Icons through 1820 to 2533 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Animation: 1820 to 23,25, Navigation: 2426 and25,and27, Editor Profiles: 2628 to 29,31, Scripting System: 3032 and 31)33)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
