Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
  1. Create a new solution
  2. Opne an existing solution
  3. Save solution...
  4. Open asset library generator dialog...
  5. Open safety asset library generator dialog...
  6. Run/Stop Player/Embedded Player, Update Embedded Player
  7. Select Player/Embedded Player setting
  8. Open automation scripts dialog...
  9. Undo
  10. Redo
  11. Add a new 2D scene
  12. Add a new 3D scene
  13. Add a new safety scene
  14. Select active scene
  15. Select perspective (Scene Design/Animation Design/User created perspective)
  16. Open Culture solution option dialog
  17. Select culture
  18. Create new animation
  19. Select animation
  20. Start animation
  21. Stop animation
  22. Animation fast forward speed
  23. Animation fast forward
  24. Go back to one previous active item
  25. Go forward to one previous active item
  26. Edit current profile
  27. Add a new profile
  28. Delete current profile
  29. Select profile
  30. Start the execution of the script system
  31. Stop the execution of the script system
Icons through 18 to 25 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Animation: 18 to 23, Navigation: 24 and25, Editor Profiles: 26 to 29, Scripting System: 30 and 31)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
